RDB board is usually positioned as low-cost, whereas DS board is typically full-featured.
For P2020 processor you can look both board photos on our web to see the difference.
P2020DS
http://cache.freescale.com/files/graphic/block_diagram/P2020DS_BD.jpg
P2020RDB
http://cache.freescale.com/files/graphic/product_freescale/P2010RDB.jpg
Visible differences - DIMM slot for memory on DS board, two x16 PCI-E slots, one conventional PCI slot, slot for SGMII riser card, SATA connectors, SD card, USB connectors
