Low disk space
Low disk space
1,890 次查看
aravindganesan
Hello
I have installed QorIQ SDK V1.6 in Ubuntu 12.04.
I have also setuo the host environment.
Now I have to install RapidIO driver.
But I am getting a warning saying:""""Low disk space:::Only 300 bytes of space remaining""""""
I am running Ubuntu as a dual-OS along with Windows7.
Though I am not having enough space in my /home partition(that is where the SDK1.6 is installed) i am having 200GB space as an external volume(mounted separately).
So can i just copy the QorIQ folder installed in my /home to my external volume and continue my further installations?
Or should I repeat the entire process again by creating more space in /home for which i will have to reinstall Ubuntu.
Please advise.
标记 (3)
1,748 次查看
sam_lee
yes,I think you can copy the SDK to other storage location and creat a soft link to the SDK in the old installed directory. I did it before and it works.
hopes it help.
Sam
1,748 次查看
aravindganesan
Dear Sam Lee,
Thanks for your clue.
I will try.
Aravind
