LS1046A max DDR4 size support
2,359件の閲覧回数
YanjunLuo
The LS1046ARDB's document said it supports 8GB DDR4, does it support 16GB? I'm thinking about a product with LS1046A, it need support 8GB or 16GB DDR4, with/without ECC. Does it possible? Can you just put a DDR4 slot as LS1046ARDB? I found it connects all 4 chip selects and address lines to the slot already.
Thank you!
Yanjun Luo.
2 返答(返信)
2,113件の閲覧回数
Bulat
The LS1046A defenitely supports 16GB of DDR4 memory. The  LS1046ARDB is equipped with 8GB uDIMM, that is why its documentation mentions this memory size.
Bulat
2,113件の閲覧回数
YanjunLuo
Thanks, I'll try it out later.
Yanjun Luo.
