LS1046A Serdes
LS1046A Serdes
tian_shuliang
I want to connect minipcie using ls1046a's serdes2 lane0, so i modify the following configuration based on FRWY-LS1046A-AC code.
file : rcw_1600_sdboot.rcw
code :
SRDS_PRTCL_S1=12352
SRDS_PRTCL_S2=21766   //FRWY use 1286
SRDS_PLL_REF_CLK_SEL_S1=0
SRDS_PLL_REF_CLK_SEL_S2=0
SRDS_PLL_PD_S1=2
SRDS_PLL_PD_S2=0
SRDS_DIV_PEX_S1=0
SRDS_DIV_PEX_S2=0
DDR_REFCLK_SEL=1
SRDS_REFCLK_SEL_S1=0
SRDS_REFCLK_SEL_S2=0
I want to know is there any other code that needs to be modified?
ufedor
No additional code has to be modified.
I believe that the custom board is in question.
