LS1046A RCW
5,450件の閲覧回数
tian_shuliang
How to select rcw_1600_sdboot.rcw or rcw_1800_sdboot.rcw in frwy-ls1046a-ac code ?
5,251件の閲覧回数
yipingwang
For LS1046ARDB, 1800MHz frequency RCWs are provided in LSDK 1906 release.
For LS1046AFRWY, you could modify RCW configuration as the following to configure core frequency as 1800MHz.
SYS_PLL_RAT=7
CGA_PLL1_RAT=18
CGA_PLL2_RAT=16
5 返答(返信)
5,251件の閲覧回数
tian_shuliang
I use lsdk1812, there are rcw_1600_sdboot.rcw and rcw_1800_sdboot.rcw. I want to know how to set different core freq.
Why ls1046a does not support 18000 MHZ frequency in lsdk1906 code?
5,251件の閲覧回数
yipingwang
LSDK 1812 doesn't support frwy-ls1046a.
5,251件の閲覧回数
tian_shuliang
5,252件の閲覧回数
yipingwang
SYS_PLL_RAT=7
CGA_PLL1_RAT=18
CGA_PLL2_RAT=16
5,251件の閲覧回数
yipingwang
Hello salmon tian,
In LSDK 1906, only rcw_1600_sdboot.rcw(core frequency of 1600MHz) is provided.
Yiping
