LS1043A PBI commands
2,570 次查看
j_wallace
According to several posts PBI command "write 0x570604, 0x40010000" is required to locate bootloader. So what is the mandatory minimum set of commands to boot. I have a custom board and I need to start with minimal configurations.
Best regards.
标记 (2)
2,196 次查看
ufedor
It is recommended to refer to the complete LS1043ARDB RCW from NXP LSDK because it in addition to U-Boot start address contains several errata workarounds:
rcw/rcw_1600.rcw at integration · qoriq-open-source/rcw · GitHub
2,196 次查看
j_wallace
OK. Great. Thanks for your quick reply
