LS1043A Gateway
LS1043A Gateway
usingbothmuxand
we bought a board LS1043A Gateway board from NXP. As per the document i have connected a usb serial cable to my PC. i am unable to get uboot prompt. Nothing is displayed on console. i have configured PC console to 115200 baud rate.  by default any uboot is programmed on the device? i have configured Dipswitches to NAND boot.
yipingwang
On your host PC, please make sure mbed USB driver is installed, please refer to  "http://mbed.org/handbook/Windows-serial-configuration".
Please download "LS1043A Residential Gateway (RGW) Getting Started Guide" from https://www.nxp.com/webapp/sps/download/preDownload.jsp?render=true, please refer to section "6 Switch configurations" to configure the target board as boot from NAND flash to check whether there is output from the console.
Please download ASK Loadable binaries for LS1043A from the
following location.
https://www.nxp.com/design/software/development-software/
vortiqa-software-for-networking/vortiqa-application-solutionskits/layerscape-1043a-multicore-communications-processorbroadband-home-router-application-solutions-kit:QORIQLS1043A-BHR-ASK?tab=Design_Tools_Tab
Please deploy SD boot image on your host PC, then plug in SD card to LS1043ARGW, and configure the target board as boot from SD card to check whether there is output from the console.
