ISI exception
ISI exception
2,930件の閲覧回数
hv
I'm at a loss as to why a section of code raises an ISI exception even though the TLB has been mapped with an UX permission.  I would appreciate any ideas/suggestions as to what I could be missing.  Thanks!
3 返答(返信)
2,792件の閲覧回数
alexander_yakov
Have you checked twice SRR0, SRR1 and MSR register contents, when the exception is taken?
2,792件の閲覧回数
hv
The ISI exception goes away when I set the SR bit (supervisor read) to 1. Why would that be?
2,792件の閲覧回数
hv
I checked them. The SRR0 points to a thread running in a memory section that was mapped with Memory coherence required, UX and UR bits are set to 1. SRR1 is shown to be 0x0000F902 (PR bit is set).
That’s why I didn’t understand why an ISI exception happened.
