HOW TO TRIGGER IFC GPCM MODE
1,763件の閲覧回数
Yangjk
l have a custom board ls1043a, when I want to trigger the operation on nand flash control mode,I can operate  the  NAND Operation Sequence Start register( IFC_NANDSEQ_STRT).
Now I want to trigger the operation on GPCM control mode,which register should I operate?
2 返答(返信)
1,701件の閲覧回数
yipingwang
My understanding in acknowledgement mode when CSORn[WGETA]=0(The access is a write, BCTL remains high for the whole duration) is as follows:
The timing settings of IFC_CSORn_GPCM[TRHZ] and IFC_GCR[BCTLD] are ignored(invalid).
1,699件の閲覧回数
Yangjk
Thank you for your answer, my understand :
if my LS1043 board wants to transfer data to external board , needs external board send signal on the external pin IFCTA_B . When LS1043 board receives this signal on the pin IFCTA_B, then transfer data to external board ?
