FMC crashes
FMC crashes
5,028 次查看
manjunathmandya
  We have LS1043A RDB board, we downloaded SDK 0.5 version from NXP website. We compiled the code under yocto environment. After booting we tried running FMC tool on the target, but it crashed. I have attached the log
Stopping Bootlog daemon: bootlogd.
Poky (Yocto Project Reference Distro) 1.6.1 ls1043ardb /dev/ttyS0
ls1043ardb login: root
root@ls1043ardb:~# cd ..
root@ls1043ardb:/home# cd ..
root@ls1043ardb:/# fmc -c /etc/fmc/config/private/ls1043ardb/RR_FQPP_1455/config.xml -p /etc/fmc/config/private/ls1043ardb/RR_FQPP_1455/policy_ipv4.xml -a
CPU: 2 PID: 3228 Comm: fmc Not tainted 3.19.3+ #1
Hardware name: LS1043A RDB Board (DT)
Call trace:
[<ffffffc00008a154>] dump_backtrace+0x0/0x12c
[<ffffffc00008a290>] show_stack+0x10/0x1c
[<ffffffc0006c39a4>] dump_stack+0x88/0xd8
[<ffffffc0004a4a1c>] QmEnqueueCB+0x194/0x254
[<ffffffc00048afc8>] FmHcPcdKgSetScheme+0x14c/0x504
[<ffffffc00045664c>] FM_PCD_KgSchemeSet+0x1d4/0x7d8
[<ffffffc0004a77e8>] LnxwrpFmPcdIOCTL+0x3e4/0x8fdc
[<ffffffc0004b0bd4>] LnxwrpFmIOCTL+0x568/0xd60
[<ffffffc0004b3cb8>] fm_ioctls+0x5c/0xf4
[<ffffffc0004b3df8>] fm_ioctl+0x44/0x64
[<ffffffc0001a21b4>] do_vfs_ioctl+0x31c/0x5bc
[<ffffffc0001a24d4>] SyS_ioctl+0x80/0x98
cpu 2: ! MINOR FM Error [CPU02, drivers/net/ethernet/freescale/fman/src/wrapper/lnxwrp_fm_port.c:283 QmEnqueueCB]: Write Access Failed;
cpu 2: timeout waiting for Tx confirmationcpu 2:
cpu 2: ! MINOR FM-PCD Error [CPU02, drivers/net/ethernet/freescale/fman/Peripherals/FM/HC/hc.c:218 EnQFrm]: Write Access Failed;
cpu 2: HC enqueue failedcpu 2:
cpu 2: ! MINOR FM-PCD Error [CPU02, drivers/net/ethernet/freescale/fman/Peripherals/FM/HC/hc.c:405 FmHcPcdKgSetScheme]: Write Access Failed;
cpu 2: cpu 2:
cpu 2: ! MINOR FM Error [CPU02, drivers/net/ethernet/freescale/fman/src/wrapper/lnxwrp_ioctls_fm.c:3290 LnxwrpFmPcdIOCTL]: Invalid Value;
cpu 2: IOCTL FM PCDcpu 2:
ERR : cpu 2: *** ASSERT_COND failed [CPU02, drivers/net/ethernet/freescale/fman/Peripherals/FM/Pcd/fm_pcd.c:769 FmPcdGetHcHandle]
Invocation of FM------------[ cut here ]------------
_PCD_KgSchemeSetWARNING: CPU: 2 PID: 3228 at drivers/net/ethernet/freescale/fman/src/xx/xx_arm_linux.c:157 XX_Exit+0x20/0x28()
for fm0/port/MA
FMD: fatal error, driver can't go on!!!
C/1/dist/udpeth1Modules linked in: failed
Call trace:
[<ffffffc0000b1f3c>] warn_slowpath_common+0x94/0xcc
[<ffffffc0000b1fc0>] warn_slowpath_fmt+0x4c/0x58
[<ffffffc0004cc670>] XX_Exit+0x1c/0x28
[<ffffffc0004595f4>] FmPcdGetHcHandle+0x58/0x6c
[<ffffffc000474f04>] DetachPCD+0x54/0x19c
[<ffffffc00048349c>] FM_PORT_DeletePCD+0x2a8/0x4d8
[<ffffffc0004b2128>] LnxwrpFmPortIOCTL+0xd5c/0x2890
[<ffffffc0004b3c90>] fm_ioctls+0x34/0xf4
---[ end trace a2ce7f5648ebc92b ]---
Unable to handle kernel paging request at virtual address 00006948
pgd = ffffffc0214c4000
[00006948] *pgd=00000000a1014003, *pud=00000000a1014003, *pmd=0000000000000000
Internal error: Oops: 96000006 [#1] PREEMPT SMP
Modules linked in:
CPU: 2 PID: 3228 Comm: fmc Tainted: G        W      3.19.3+ #1
task: ffffffc0213b0000 ti: ffffffc021bf8000 task.ti: ffffffc021bf8000
PC is at FmPcdGetHcHandle+0x5c/0x6c
LR is at FmPcdGetHcHandle+0x5c/0x6c
pc : [<ffffffc0004595f8>] lr : [<ffffffc0004595f8>] pstate: 80000145
sp : ffffffc021bfbba0
x29: ffffffc021bfbba0 x28: ffffffc021bf8000
x27: ffffffc00096e000 x26: 000000000000001d
x25: 000000000000011a x24: 000000000000e15b
x23: 0000007feceb2ac0 x22: 0000000000000000
x21: 0000007feceb2ac0 x20: ffffffc021835d40
x19: 0000000000000000 x18: 0000007feceb24b0
x17: 0000007fb5a24a30 x16: ffffffc0001a2454
x15: 0000007fb5a99598 x14: 0ffffffffffffffd
x13: 0000000000000018 x12: 0000000000000006
x11: 0000000000000000 x10: 0000000000000195
x9 : 0000000000000196 x8 : 3436356637656332
x7 : ffffffc000964508 x6 : 000000000000000f
x5 : ffffffc0003627f8 x4 : 0000000000000007
x3 : 0000000000000200 x2 : 0000000000000200
x1 : ffffffc0009cc358 x0 : 0000000000000000
Process fmc (pid: 3228, stack limit = 0xffffffc021bf8058)
Stack: (0xffffffc021bfbba0 to 0xffffffc021bfc000)
bba0: 21bfbbc0 ffffffc0 00474f08 ffffffc0 76b06000 ffffffc0 21d10000 ffffffc0
bbc0: 21bfbc00 ffffffc0 004834a0 ffffffc0 76b06000 ffffffc0 0000001d 00000000
bbe0: 21bfbbf0 ffffffc0 004ccaf4 ffffffc0 21bfbc00 ffffffc0 00483498 ffffffc0
bc00: 21bfbc50 ffffffc0 004b212c ffffffc0 0000e15b 00000000 21d110f0 ffffffc0
bc20: eceb2ac0 0000007f 0019c918 ffffffc0 21bfbce0 ffffffc0 0019ec90 ffffffc0
bc40: 21bfbdb0 ffffffc0 21bfbea8 ffffffc0 21bfbdb0 ffffffc0 004b3c94 ffffffc0
bc60: 76bea700 ffffffc0 0000e15b 00000000 21defd38 ffffffc0 00000005 00000000
bc80: eceb2ac0 0000007f 0000e15b 00000000 0000011a 00000000 0000001d 00000000
bca0: 21bfbcc0 ffffffc0 0035e7fc ffffffc0 009e81a8 ffffffc0 215db800 ffffffc0
bcc0: 21bfbcd0 ffffffc0 0035e840 ffffffc0 21bfbd00 ffffffc0 0035e858 ffffffc0
bce0: 21bfbcf0 ffffffc0 000e25c8 ffffffc0 21bfbd10 ffffffc0 0034494c ffffffc0
bd00: 21bfbd10 ffffffc0 00344970 ffffffc0 21bfbd60 ffffffc0 000e2610 ffffffc0
bd20: 215dba30 ffffffc0 00000140 00000000 215db800 ffffffc0 b5a97fd4 0000007f
bd40: 21bfbdb0 ffffffc0 004b3cbc ffffffc0 76beab00 ffffffc0 0000e116 00000000
bd60: 21deec28 ffffffc0 00000004 00000000 215db800 ffffffc0 21ca69b8 ffffffc0
bd80: 21bfbe30 ffffffc0 00190f98 ffffffc0 215ec100 ffffffc0 00000001 00000000
bda0: 21ca69b8 ffffffc0 00000002 00000000 21bfbde0 ffffffc0 004b3dfc ffffffc0
bdc0: 76bea700 ffffffc0 004a1170 ffffffc0 21bfbde0 ffffffc0 004b3de4 ffffffc0
bde0: 21bfbe10 ffffffc0 001a21b8 ffffffc0 76bea700 ffffffc0 eceb2ac0 0000007f
be00: 00000008 00000000 eceb2ac0 0000007f 21bfbe90 ffffffc0 001a24d8 ffffffc0
be20: 76bea700 ffffffc0 00000000 00000000 76bea700 ffffffc0 00000005 00000000
be40: 215ec100 ffffffc0 215ec100 ffffffc0 ffffffff ffffffff b5a1fa7c 0000007f
be60: 60000000 00000000 001918e8 ffffffc0 21bfbe80 ffffffc0 001ac3f8 ffffffc0
be80: 21bfbe90 ffffffc0 001a2494 ffffffc0 eceb2b00 0000007f 00086430 ffffffc0
bea0: 00000000 00000000 02fd5990 00000000 ffffffff ffffffff b5a24a3c 0000007f
bec0: 80000000 00000000 00000015 00000000 00000005 00000000 0000e15b 00000000
bee0: eceb2ac0 0000007f eceb2ad0 0000007f eceb2aa0 0000007f ffffffff 00000000
bf00: 00000000 00000000 eceb2798 0000007f 0000001d 00000000 fefefeff fefefefe
bf20: ffffffff 00000000 01010101 01010101 00000038 00000000 00000000 00000000
bf40: 00000000 00000000 b5a99598 0000007f 005602f8 00000000 b5a24a30 0000007f
bf60: eceb24b0 0000007f 02f1fde8 00000000 02fd5990 00000000 02fd5fd8 00000000
bf80: 00000025 00000000 0051eef0 00000000 0051ee10 00000000 00000000 00000000
bfa0: 0051efd8 00000000 eceb30a8 0000007f eceb2ef8 0000007f eceb2b00 0000007f
bfc0: 0051b7b8 00000000 eceb2b00 0000007f b5a24a3c 0000007f 80000000 00000000
bfe0: 00000005 00000000 0000001d 00000000 00000000 00000000 00000000 00000000
Call trace:
[<ffffffc0004595f8>] FmPcdGetHcHandle+0x5c/0x6c
Code: 9138e000 9401cc24 52800020 9401cc18 (f974a660)
---[ end trace a2ce7f5648ebc92c ]---
Segmentation fault
  Please let me know how to go about this. Without performing this we cannot receive anything on the port.
Manjunath
7 回复数
4,490 次查看
manjunathmandya
Hi Yiping,
    Thanks for reply, i did not tried default image. I compiled the code ( SDK 0.5 ) under yocto and executed the image kernel-fsl-ls1043a-rdb.dtb-ls1043ardb.itb on ls1043ardb board.
    I have attached kernel configuration, only change i have done to default kernel setting is enabling QDMA under device driver.
Manjunath
4,490 次查看
yipingwang
Hello Manjunath Mandya,
There is no problem in the Kernel configuration file.
Did you use u-boot from SDK 0.5? Did you use FMAN ucode fsl_fman_ucode_t2080_r1.1_106_4_17.bin?
Would you please also provide u-boot and Linux Kernel boot up log?
Yiping
4,489 次查看
manjunathmandya
Hi Yiping,
      Ok, we did not used u-boot from SDK 0.5, LS1043A rdb had version "2015.01QorIQ-SDK-V1.7+g503273b " u-boot, also we did not used FMAN ucode.
      I have attached the log file while booting the system.
Manjunath M N
4,489 次查看
yipingwang
Hello Manjunath M N,
Please also update u-boot, FMAN microcode and RCW on your target board with images from SDK 0.5 pre_built image ISO.
Yiping
4,488 次查看
manjunathmandya
  Any updates on this ? Am i only one who is getting this crash ?
Manjunath
4,489 次查看
yipingwang
Please also use RCW for  RR_FQPP_1455 on your target board.
Did you build kernel image with the default kernel configuration file? Have you tried the pre-built kernel itb image on your target?
If your problem remains, would you please also provide u-boot and kernel boot up log?
Yiping
4,488 次查看
yipingwang
Hello Manjunath,
I verified the pre-built image kernel-fsl-ls1043a-rdb.dtb-ls1043ardb.itb in the ISO Linux-SDK-for-LS1043A-V0.5-IMAGE-20151223-yocto without any problem. If you didn't use the default Kernel configuration file, please also provide your Kernel config file.
Yiping
