Error running DCE example
2,347件の閲覧回数
G2Dom
Any ideas on this error when trying to the DCE examples from:
I run to setup:
  sudo restool dprc create dprc.1 --label="DCE test dprc"
  sudo restool dpio create
  sudo restool dpdcei create --priority=1 --engine=DPDCEI_ENGINE_COMPRESSION
  sudo restool dpdcei create --priority=1 --engine=DPDCEI_ENGINE_DECOMPRESSION
  sleep 1
  sudo restool dprc assign dprc.1 --child=dprc.2 --object=dpio.16 --plugged=1
  sudo restool dprc assign dprc.1 --child=dprc.2 --object=dpio.17 --plugged=1
  sudo restool dprc assign dprc.1 --child=dprc.2 --object=dpio.18 --plugged=1
  sudo restool dprc assign dprc.1 --child=dprc.2 --object=dpdcei.0 --plugged=1
  sudo restool dprc assign dprc.1 --child=dprc.2 --object=dpdcei.1 --plugged=1
  sudo restool dprc assign dprc.1 --child=dprc.2 --object=dpdcei.2 --plugged=1
  sudo restool dprc assign dprc.1 --child=dprc.2 --object=dpdcei.3 --plugged=1
  sudo restool dprc assign dprc.1 --child=dprc.2 --object=dpdcei.4 --plugged=1
  sudo restool dprc assign dprc.1 --child=dprc.2 --object=dpdcei.5 --plugged=1
and running "sudo restool dprc show dprc.2" returns
dprc.2 contains 9 objects:
object        label        plugged-state
dpdcei.5            plugged
dpdcei.4            plugged
dpdcei.3            plugged
dpdcei.2            plugged
dpdcei.1            plugged
dpdcei.0            plugged
dpio.18                plugged
dpio.17                plugged
dpio.16                plugged
Now running the example:
sudo bin/dce-example dprc.2 dpio.16 dpdcei.0 dpdcei.5
SETUP Data Path Objects ***************************************************************
Worker dce-example: Setup MC resources
Worker dce-example: Open root dprc
Worker dce-example: Open test dprc
Worker dce-example: Setup vfio to allow HW devices to access virtual addresses
Worker dce-example: Allocate virtual memory and map it to test dprc using vfio
Worker dce-example: Setup QBman Software Portal
ioctl(RESTOOL_SEND_MC_COMMAND) failed with error -13
ERR: dce_helper_swp_init: error -13 in dce_helper_swp_init in attempt to dpio_reset()
ERR: main: Software Portal init from dpio.16 failed
Dom
5 返答(返信)
2,323件の閲覧回数
G2Dom
I did find this error in syslog
Dec 15 18:40:22 dam2 kernel: [ 2079.761261] fsl_mc_dprc dprc.1: MC command 0x0051: cmdid not accepted
Dec 15 18:41:26 dam2 kernel: [ 2143.809773] fsl_mc_dprc dprc.1: MC command 0x0051: cmdid not accepted
2,269件の閲覧回数
yipingwang
Please use images from the same LSDK release.
Please download firmware image and Linux Kernel from LSDK 21.08 release.
$ wget https://www.nxp.com/lgfiles/sdk/lsdk2108/firmware_lx2160ardb_rev2_xspiboot.img
$ wget https://www.nxp.com/lgfiles/sdk/lsdk2108/boot_LS_arm64_lts_5.10.tgz
2,328件の閲覧回数
G2Dom
I think this maybe something in my kernel configuration, because just tried it on a dev box with a older OS and it works.
2,335件の閲覧回数
yipingwang
Please execute the following commands before executing dce-example.
root@localhost:~# echo vfio-fsl-mc > /sys/bus/fsl-mc/devices/dprc.2/driver_override
root@localhost:~# echo dprc.2 > /sys/bus/fsl-mc/drivers/vfio-fsl-mc/bind
2,330件の閲覧回数
G2Dom
Thanks for this reply, however no luck:
root@dam2:~/dom/dce# sudo restool dprc create dprc.1 --label="DCE test dprc"
sleep 1
dprc.2 is created under dprc.1
dpio.16 is created under dprc.1
dpio.17 is created under dprc.1
dpio.18 is created under dprc.1
dpdcei.0 is created under dprc.1
dpdcei.1 is created under dprc.1
dpdcei.2 is created under dprc.1
dpdcei.3 is created under dprc.1
dpdcei.4 is created under dprc.1
dpdcei.5 is created under dprc.1
root@dam2:~/dom/dce# echo vfio-fsl-mc > /sys/bus/fsl-mc/devices/dprc.2/driver_override
root@dam2:~/dom/dce# echo dprc.2 > /sys/bus/fsl-mc/drivers/vfio-fsl-mc/bind
root@dam2:~/dom/dce# bin/dce-example dprc.2 dpio.16 dpdcei.0 dpdcei.5
Does dce_helper_swp_init depend on any kernel module?
Dom
