Considerations when select the SFP + transceiver module
sun_lee
Hi, I have a LS1046A-RDB_revB and i am trying to use 10G SFP+ .
So, i try to buy the SFP+ transceiver module.
Before purchasing an SFP + transceiver module, I would like to know what to consider when selecting a module.
I want to know what to check such as Compatibility, Single mode, Multi mode, etc.
And let me know if you have a recommended SFP+ transceiver module.
thanks.
ufedor
Finisar FTLX8571D3BCL was tested with the LS1046ARDB.
