CAAM SEC engine support on Yocto SDK LS1046 or LS2088
antonio_santagi
I am using YOCTO SDK , Dunfell branch, for LS1046 and LS2088 and OP-TEE.
I can't see where and if the CAAM SEC is enabled for HW acceleration of cryptographic operations on OP-TEE.
Does OP-TEE make use of the CAM SEC by default or not  on this platform ? I have found contradictory information online.
If not, can I enable it ?
thank you
Tags (4)
