Build Second Program Loader
ソリューションへジャンプ
2,185件の閲覧回数
vinothkumars
Senior Contributor IV
Hi All,
I want to build u-boot binary with fixed_sdram (DDR) alone. From the nxp thread understand It will possible by build Second Program Loader (SPL).
Please provide configuration or commands to build the u-boot-spl.bin (or)  build alone with fixed_sdram (ddr) for T4240RDB-64B Machine.
Thank you for all your support...............!
Thanks & Regards,
VinothS
Vinothkumar Sekar
2,049件の閲覧回数
vinothkumars
Hi All,
I done the built "u-boot-spl.bin" by change the configuration(T4240RDB_SDCARD)  in machine config file.
               <SDK Installation Path>/QorIQ-SDK-V2.0-20160527-yocto/sources/meta-freescale/conf/machine/t4240rdb-64b.conf
Is it wright way to build u-boot binary with fixed_sdram (DDR) alone ?
Thank you for all your support...........!
Regards, VinothS
Vinothkumar Sekar
2,050件の閲覧回数
vinothkumars
Hi All,
Regards, VinothS
Vinothkumar Sekar
