Traffic Bifurcation Between DPDK and Linux Kernel using DPDMUX
DPDMUX is a device like DPSW (Switch) which allows switching of packets within the DPAA2 blocks. This application adds DPDMUX support in DPDK, uses LS2088ARDB as an example platform for demonstrating the use case that traffic bifurcation between DPDK and Linux Kernel using DPDMUX on DPAA2 platform.
%3CLINGO-SUB%20id%3D%22lingo-sub-1124271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETraffic%20Bifurcation%20Between%20DPDK%20and%20Linux%20Kernel%20using%20DPDMUX%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1124271%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDPDMUX%20is%20a%20device%20like%20DPSW%20(Switch)%20which%20allows%20switching%20of%20packets%20within%20the%20DPAA2%20blocks.%20This%20application%20adds%20DPDMUX%20support%20in%20DPDK%2C%20uses%20LS2088ARDB%20as%20an%20example%20platform%20for%20demonstrating%20the%20use%20case%20that%20traffic%20bifurcation%20between%20DPDK%20and%20Linux%20Kernel%20using%20DPDMUX%20on%20DPAA2%20platform.%3C%2FP%3E%3C%2FLINGO-BODY%3E
100% helpful (1/1)
Version history
Last update:
‎07-28-2019 11:50 PM
Updated by:
