QorIQ SDK build for T4240QDS - Beginner's guide
This tutorial details the basics of how to boot up a Freescale T4240QDS board and also explains how to build an image in yocto and boot it up on the board.
The intended audience is an absolute beginner who is new to the yocto build and working on a board like T4240
Download the QorIQ SDK from freescale’s site. The SDK site can be found in:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=SDKLINUX
The version that is used in this documentation is version 1.4. Version 1.4 can be found in:
http://www.freescale.com/webapp/sps/site/overview.jsp?code=QORIQSDK_1.4
The SDK has 3 important components,
The source ISO – The actual SDK source that we are going to use.
The cache state ISO – These files contain sstate-cache directory, i.e all packages pre-downloaded, this
makes the build run faster.
The image ISO – These are pre-built images for all Freescale targets. This is not required for this tutorial,
since we are building our own images.
The name of the source ISO that you are looking for is: QorIQ Linux SDK v1.4 Yocto Source ISO
Once you click  Source, go ahead and login when the site prompts.
Download the source ISO, we are going to work on this.
Open a terminal
Create the iso directory
qoriq@usernsl-Veriton-Series:~$ sudo mkdir /media/sourceiso
Mount the iso.
qoriq@usernsl-Veriton-Series:~$ sudo mount -o loop Downloads/QorIQ-SDK-V1.4-SOURCE-20130625-yocto.iso /media/sourceiso/
Change into source directory
qoriq@usernsl-Veriton-Series:~$ cd /media/sourceiso/
Copy the source SDK
qoriq@usernsl-Veriton-Series:/media/sourceiso$ sudo cp yocto.tar.gz ~/
Change into working directory
qoriq@usernsl-Veriton-Series:/media/sourceiso$ cd
Create the root SDK directory
qoriq@usernsl-Veriton-Series:~$ mkdir yocto
Move the gzip file into directory
qoriq@usernsl-Veriton-Series:~$ mv yocto.tar.gz yocto/
qoriq@usernsl-Veriton-Series:~$ cd yocto/
Unzip the source
qoriq@usernsl-Veriton-Series:~/yocto$ tar xvf yocto.tar.gz
View the source files/directories
qoriq@usernsl-Veriton-Series:~/yocto$ ls
bitbake LICENSE meta-fsl-ppc meta-oe  meta-yocto README sources documentation meta meta-fsl-ppc-toolchain meta-skeleton meta-yocto-bsp README.hardware yocto.tar.gz fsl-setup-poky meta-fsl-networking meta-hob meta-virtualization oe-init-build-env scripts
Preparing the kernel
Freescale kernel is configured in the layer ‘yocto/meta-fsl-ppc/recipes-kernel/linux’ folder. It containes recipes (.bb) files that tell the SDK how to download/configure/install the kernel. There are 2 portions to the kernel configuration, one is the kernel itself (linux-qoriq-sdk.bb file) and the kernel headers (linux-qoriq-sdk-headers.bb file). First we are going to show how to prepare the kernel to change the kernel sources within the kernel recipes. This can help us modify the sources.
Move into home directory
qoriq@usernsl-Veriton-Series:~/yocto$ cd ..
Download the freescale kernel that is going to be built for the target
qoriq@usernsl-Veriton-Series:~$ git clone git://git.freescale.com/ppc/sdk/linux.git
Cloning into 'linux'...
remote: Counting objects: 2931244, done.
remote: Compressing objects: 100% (481548/481548), done.
remote: Total 2931244 (delta 2449497), reused 2902973 (delta 2421384)
Receiving objects: 100% (2931244/2931244), 581.84 MiB | 92 KiB/s,
done.
Resolving deltas: 100% (2449497/2449497), done.
Rename the kernel tree to the Yocto compatible directory (this makes  the build run error free, with minimal changes)
qoriq@usernsl-Veriton-Series:~$ mv linux/ linux-qoriq-sdk
Create a gzip file of the kernel source
qoriq@usernsl-Veriton-Series:~$ tar zcvf linux-qoriq-sdk.tar.gz linux-qoriq-sdk/
Generate the md5sum of the kernel gzip, (used in the build conf file)
qoriq@usernsl-Veriton-Series:~$ md5sum linux-qoriq-sdk.tar.gz
986feb8581d3521f295884270d7cc5f2 linux-qoriq-sdk.tar.gz
Now the kernel is ready to be given as input to the build environment.  The kernel sources (from where the kernel is downloaded/fetched) is, by default, the freescale git repository. Since we downloaded the kernel from the same repository we should remember to change the kernel sources to the gzip file that we created. We show how to do this, further in this tutorial.
The Build proceedure
These are the build commands to generate the images.
Change into the yocto directory
qoriq@usernsl-Veriton-Series:~ cd yocto
Source the environment
qoriq@usernsl-Veriton-Series:~/yocto$ source fsl-setup-poky -m
Configuring for t4240qds board type
Creating an yocto build output at /home/qoriq/yocto/
build_t4240qds_release
Run the following commands to start a build:
          bitbake fsl-image-core
          bitbake fsl-image-lsb-sdk
          bitbake fsl-image-flash
          bitbake fsl-image-full
          bitbake fsl-image-kvm
          bitbake fsl-image-minimal
To return to this build environment later please run:
          source /home/qoriq/yocto/build_t4240qds_release/SOURCE_THIS
Sourcing the environment makes all the yocto commands(bitbake, runqemu, runqemu-extract-sdk, yocto-layer etc.) available, it also creates a default environment that can be configured to build for various different architectures and machines. The two important configuration files that need to be modified are:
               conf/local.conf
               conf/bblayers.conf
We will see what these files contain and what we are going to modify.
Open conf/local.conf
qoriq@usernsl-Veriton-Series:~/yocto/build_t4240qds_release$ nano conf/local.conf
Find the line that has :
#BB_NUMBER_THREADS = "4"
Uncomment the line and change it into
BB_NUMBER_THREADS = "8"
This creates 8 threads and does the build in parallel.
Find the line that has:
#PARALLEL_MAKE = "-j 4"
Uncomment and change it into
PARALLEL_MAKE = "-j 8"
This variable is sent as parameter to all make invocation and performs the make in parallel with 8 threads
MACHINE ??= "qemux86"
And replace with:
MACHINE ??= "t4240qds"
This variable determines the machine that the image is built for.  “qemux86” is a x86 image that can be run virtually on the host system. “t4240qds” is the machine that we are building the images for.
Hit Ctrl + X to exit
Configuring kernel recipes
Move to yocto folder
qoriq@usernsl-Veriton-Series:~/yocto/build_t4240qds_release $ cd ..
Change into the kernel recipe directory
qoriq@usernsl-Veriton-Series:~/yocto$ cd meta-fsl-ppc/recipes-kernel/linux/
The directory contains a set of files.
All .bb files are recipes and they contain configurations to fetch/configure/compile/install packages.All .inc files are include files, they are included within the corresponding .bb file with the “require “ command
The files linux-qoriq-sdk.* are files that configure the kernel.
The files linux-qoriq-sdk-headers.* are files that configure the header files for the kernel
We need to separate the sources for the kernel and the headers and then configure the kernel sources to point to the kernel that we have already zipped and made available
Make a copy of linux-qoriq-sdk.inc and keep it as linux-qoriq-sdk-headers.inc
qoriq@usernsl-Veriton-Series:~/yocto/meta-fsl-ppc/recipes-kernel/linux$ cp linux-qoriq-sdk.inc linux-qoriq-sdk-headers.inc
Open linux-qoriq-sdk-headers.inc
qoriq@usernsl-Veriton-Series:~/yocto/meta-fsl-ppc/recipes-kernel/linux$ nano linux-qoriq-sdk-headers.bb
require recipes-kernel/linux/linux-qoriq-sdk.inc
Edit it to:
require recipes-kernel/linux/linux-qoriq-sdk-headers.inc
We have separated the sources for the kernel and the headers, now we proceed to edit the sources of the kernel
Open linux-qoriq-sdk.inc file
qoriq@usernsl-Veriton-Series:~/yocto/meta-fsl-ppc/recipes-kernel/linux$ nano linux-qoriq-sdk.inc
Edit the file to look like:
## File starts here ##
LIC_FILES_CHKSUM = "file://COPYING;md5=d7810fab7487fb0aad327b76f1be7cd7"
PV = "3.8"
INC_PR = "r9"
#SRCREV = "4b66366af2d77de68f4bd6548d07421e13d3df05"
#SRC_URI = "git://git.freescale.com/ppc/sdk/linux.git \
SRC_URI = "file:///home/qoriq/linux-qoriq-sdk.tar.gz"
SRC_URI[md5sum] = "986feb8581d3521f295884270d7cc5f2"
KSRC ?= ""
S = '${@base_conditional("KSRC", "", "${WORKDIR}/linux-qoriq-sdk", "${KSRC}", d)}'
# make everything compatible for the time being
COMPATIBLE_MACHINE_$MACHINE = "$MACHINE"
python () {
ma = d.getVar("DISTRO_FEATURES", True)
arch = d.getVar("OVERRIDES", True)
# the : after the arch is to skip the message on 64b
if not "multiarch" in ma and ("e5500:" in arch or "e6500:" inarch):
arch requires multiarch to be in DISTRO_FEATURES")
promote_kernel = d.getVar('BUILD_64BIT_KERNEL')
if promote_kernel == "1":
     raise bb.parse.SkipPackage("Building the kernel for this
     d.setVar('KERNEL_CC_append', ' -m64')
     d.setVar('KERNEL_LD_append', ' -melf64ppc')
error_qa = d.getVar('ERROR_QA', True)
if 'arch' in error_qa:
     d.setVar('ERROR_QA', error_qa.replace(' arch', ''))
all_qa = d.getVar('ALL_QA', True)
if 'arch' in all_qa:
     d.setVar('ALL_QA', all_qa.replace(' arch', ''))
## File ends here ##
(( Note: It is adviceable to copy the entire contents above and replace with the contents of the file. If you are unable to copy the above source and have it properly aligned, follow the list of changes below and change it manually:
Find the variable INC_PR and set it to
INC_PR = “r9”
Comment out the existing SRCREV and SRC_URI variable:
And replace with the sources you had built
SRC_URI = file:///home/qoriq/linux-qoriq-sdk.tar.gz
SRC_URI[md5sum] = “986feb8581d3521f295884270d7cc5f2”
Make sure the entered md5sum matches that of the kernel source available in that particular location.
The build sets a variable S as:
S = '${@base_conditional("KSRC", "", "${WORKDIR}/git", "${KSRC}", d)}'
We need to modify it as:
Building the image
Now we are ready to run the build, After sourcing the environment, we find that the bitbake (build command) can generate various images:
These images provide various different functionality within the image, we are going to use the image: fsl-image-core as it can generate a bootable and minimal image with adequate functionality.
The build can take a long time to run.
Change to build directory
qoriq@usernsl-Veriton-Series:~/yocto/meta-fsl-ppc/recipes-kernel/linux$ cd ~/yocto/build_t4240qds_release/
qoriq@usernsl-Veriton-Series:~/yocto/build_t4240qds_release$ bitbake fsl-image-core
Loading cache: 100% |#################################################################################################| ETA: 00:00:00
Loaded 3120 entries from dependency cache.
Build Configuration:
BB_VERSION = "1.18.0"
BUILD_SYS = "i686-linux"
NATIVELSBSTRING = "Ubuntu-12.04"
TARGET_SYS = "powerpc-fsl_networking-linux"
MACHINE = "t4240qds"
DISTRO = "fsl-networking"
DISTRO_VERSION = "1.4"
TUNE_FEATURES = "m32 fpu-hard e6500 altivec"
TARGET_FPU = "hard"
meta
meta-yocto
meta-yocto-bsp = "sdk-v1.4.x:5a7532143a49f59a5c85b08d3daf574fb1eccd8d"
meta-fsl-ppc = "sdk-v1.4.x:f9fd0a617eb6913f87335c551918315ff4ebe18c"
meta-fsl-ppc-toolchain = "sdk-v1.4.x:8ec94cec04527cb971c125b1ddd2c5375034d723"
meta-virtualization = "sdk-v1.4.x:ad6df4f59cd7646f61db29e8fa51f878329d6f93"
meta-fsl-networking
= "(nobranch):00f7a535029ca7ef8c96ba8e9916d4742166bab0"
meta-oe
meta-networking = "sdk-v1.4.x:7c8dd8f096b64a709175d37a08a4fb02ca263616"
NOTE: Resolving any missing task queue dependencies
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
NOTE: Tasks Summary: Attempted 3164 tasks of which 3162 didn't need to be rerun and all succeeded.
Create a temporary folder to extract the root filesystem
qoriq@usernsl-Veriton-Series:~/yocto/build_t4240qds_release$ mkdir ~/rootfs
Extract to the folder
qoriq@usernsl-Veriton-Series:~/yocto/build_t4240qds_release$ runqemu-extract-sdk tmp/deploy/images/fsl-image-core-t4240qds-20140218104652.rootfs.tar.gz ../../rootfs
(( Note: that the tar.gz file contains the root filesystem of the build and the timestamp in the filename may vary. But essentially the file that has to be extracted will be in the form:
                    fsl-image-core-t4240qds-<timestamp>.rootfs.tar.gz
Adding packages into the root filesystem
Follow this set of instructions if you want to add a sample package into the root directory, else these can be skipped. There are multiple ways with which a package can be included, refer the yocto manual for a complete list of techniques. This tutorial gives an easy way to achieve this. In the yocto, main root directory we can find various directories like “meta-*” these directories contain recipes to include packages/kernels etc. These are called layers. To create a package we are going to create a new layer and within which we are going to create a recipe and thereby a .bb file that configures the package.
The package that we are showing is the GNU package, htop.
(( Note: This set of instructions depends on the packages that is being installed, but this works for mostly GNU-licensed packages ))
Move to the home directory
Download the package
qoriq@usernsl-Veriton-Series:~$ wget http://hisham.hm/htop/releases/1.0.2/htop-1.0.2.tar.gz
--2014-02-24 14:14:40-- http://hisham.hm/htop/releases/1.0.2/htop-1.0.2.tar.gz
Resolving hisham.hm (hisham.hm)... 69.163.170.116
Connecting to hisham.hm (hisham.hm)|69.163.170.116|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 388499 (379K) [application/x-tar]
Saving to: `htop-1.0.2.tar.gz.1'
100%[======================================>] 3,88,499 169K/s in 2.2s
2014-02-24 14:14:44 (169 KB/s) - `htop-1.0.2.tar.gz.1' saved [388499/388499]
Extract the package
qoriq@usernsl-Veriton-Series:~$ tar xvf htop-1.0.2.tar.gz
Check the md5sum of the package and make note of it
qoriq@usernsl-Veriton-Series:~$ md5sum htop-1.0.2.tar.gz
0d01cca8df3349c74569cefebbd9919e htop-1.0.2.tar.gz
Check the md5sum of the COPYING file (This is to check the license of the package)
Change into the directory
qoriq@usernsl-Veriton-Series:~$ cd htop-1.0.2/
qoriq@usernsl-Veriton-Series:~/htop-1.0.2$ md5sum COPYING
c312653532e8e669f30e5ec8bdc23be3 COPYING
Yocto has a wide set of commands/scripts, yocto-layer is one such command that creates a layer. Initially we are going to create a new layer and within that layer we are going to create a recipe within the layer and the necessary .bb file to configure the package.
Move into the yocto directory
Create the layer
qoriq@usernsl-Veriton-Series:~/yocto$ yocto-layer create mylayer
Please enter the layer priority you'd like to use for the layer: [default: 6] <hit Enter>
Would you like to have an example recipe created? (y/n) [default: n] <hit Enter>
Would you like to have an example bbappend file created? (y/n) [default: n] <hit Enter>
New layer created in meta-mylayer.
qoriq@usernsl-Veriton-Series:~/yocto$ cd meta-mylayer/
Create the package directory
qoriq@usernsl-Veriton-Series:~/yocto/meta-mylayer/hello$ mkdir htop
Change into directory
qoriq@usernsl-Veriton-Series:~/yocto/meta-mylayer/hello$ cd htop
Create the config file
qoriq@usernsl-Veriton-Series:~/yocto/meta-mylayer/htop$ nano htop_1.0.2.bb
(( Note: Naming the .bb file depends on the version of the package that is being included,the format to follow is:
               <package-name>_<version number>.bb
The contents of the bb file should be like:
DESCRIPTION = "Htop performance monitor"
SECTION = "performance monitor"
LICENSE = "GPLv2+"
LIC_FILES_CHKSUM = "file://COPYING;md5=c312653532e8e669f30e5ec8bdc23be3"
PR = "r0"
SRC_URI = "file:///home/qoriq/htop-1.0.2.tar.gz"
SRC_URI[md5sum] = "0d01cca8df3349c74569cefebbd9919e"
inherit autotools gettext
Make sure you have entered the md5sum values that you have generated, and they match perfectly. Now the layer you have created should be added into the layers file conf/bblayers.conf
This file includes all the layers (of packages, kernels and other configurations) into the build, since we created a new yocto layer we need to include it in this file.
qoriq@usernsl-Veriton-Series:~/yocto/meta-mylayer/htop$ cd ../../build_t4240qds_release
Open the bblayers file
qoriq@usernsl-Veriton-Series:~/yocto/build_t4240qds_release$ nano conf/bblayers.conf
Find the BBLAYERS variable:
BBLAYERS ?= " \
                         /home/qoriq/yocto/meta \
                         /home/qoriq/yocto/meta-yocto \
                         /home/qoriq/yocto/meta-yocto-bsp \
                         /home/qoriq/yocto/meta-fsl-ppc \
                         /home/qoriq/yocto/meta-fsl-ppc-toolchain \
                         /home/qoriq/yocto/meta-virtualization \
                         /home/qoriq/yocto/meta-fsl-networking \
                         /home/qoriq/yocto/meta-oe/meta-oe \
                         /home/qoriq/yocto/meta-oe/meta-networking \
Append the location of your layer in the end
BBLAYERS ?= " \
/home/qoriq/yocto/meta-mylayer \
Save and proceed to build (as given above).
SD card layout
The SD card should contain a single ext2 partition which holds the uImage files and the root filesystem.
Insert the SD card into the host machine, and using the mount command figure out the where it is mounted and the tag of the device.
Format the disk
qoriq@usernsl-Veriton-Series:~$ sudo fdisk /dev/sdc
(( Note: The device ID of your SD card can be found out by running the mount command ))
Delete all partitions
Command (m for help): d
Selected partition 1
Print the number of partitions (Hit p and then enter)
Command (m for help): p
Disk /dev/sdc: 3965 MB, 3965190144 bytes
4 heads, 12 sectors/track, 161344 cylinders, total 7744512 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x558eef06
Device Boot Start End Blocks Id System
As expected the partition table shows empty
Create new partition (Hit n and press Enter)
Command (m for help): n
Partition type:
p primary (0 primary, 0 extended, 4 free)
e extended
Select (default p): <Hit Enter>
Using default response p
Partition number (1-4, default 1): <Hit Enter>
Using default value 1
First sector (2048-7744511, default 2048): <Hit Enter>
Using default value 2048
Last sector, +sectors or +size{K,M,G} (2048-7744511, default
7744511):
Using default value 7744511
Print to see new partition (Hit p and then Enter)
/dev/sdc1 2048 7744511 3871232 83 Linux
Write the changes and exit (Hit w and then Enter)
Command (m for help): w
The partition table has been altered!
Calling ioctl() to re-read partition table.
WARNING: Re-reading the partition table failed with error 16:
Device or resource busy.
The kernel still uses the old table. The new table will be used
atthe next reboot or after you run partprobe(8) or kpartx(8)
Syncing disks.
Create the ext2 filesystem in the created partition
qoriq@usernsl-Veriton-Series:~$ mkfs.ext2 /dev/sdc1
Copy the kernel image into the SD card
qoriq@usernsl-Veriton-Series:~$ sudo cp -d yocto/build_t4240qds_release/tmp/deploy/images/uImage* /media/7e19cd10-3ed8-436d-956c-3fdb14c84e3d/
(( Note: The –d option is necessary, it preserves all symbolic links ))
Change into the root directory
qoriq@usernsl-Veriton-Series:~ $ cd rootfs
Copy root filesystem into the SD card
qoriq@usernsl-Veriton-Series:~/rootfs$ sudo cp -Rd * /media/7e19cd10-3ed8-436d-956c-3fdb14c84e3d/
Sync
qoriq@usernsl-Veriton-Series:~/rootfs$ sync
Unmount
qoriq@usernsl-Veriton-Series:~/rootfs$ sudo umount /media/7e19cd10-3ed8-436d-956c-3fdb14c84e3d/
T4240QDS Booting
Open the serial console with
qoriq@usernsl-Veriton-Series:~ $ sudo gtkterm
Open Configuration -> Port and set the Baudrate to 115200.
Insert the SD card into the machine and power up.
A u-boot prompt appears, hit Enter to disrupt automatic booting.
Once you see the u-boot console, you’ll need to configure the environment variables
Hit print to see all environment variables, mine look like:
=> print
baudrate=115200
bdev=sda3
bootargs=root=/dev/mmcblk0p1 rw rootdelay=5 console=ttyS0,115200
bootcmd=setenv bootargs root=/dev/mmcblk0p1 rw rootdelay=5
console=$consoledev,$baudrate;mmcinfo;ext2load mmc 0:1 $loadaddr
$bootfile;ext2load mmc 0:1 $fdtaddr $fdtfile; bootm $loadaddr -
$fdtaddr
bootdelay=10
bootfile=uImage
c=ffe
consoledev=ttyS0
ethact=FM1@DTSEC5
ethprime=FM1@DTSEC1
fdtaddr=0x17200000
fdtfile=uImage-t4240qds.dtb
filesize=0x3df080
fman_ucode=0xeff40000
gatewayip=10.116.65.1
hwconfig=fsl_ddr:ctlr_intlv=3way_4KB,bank_intlv=auto;usb1:dr_mode=host,phy_type=utmi
ipaddr=10.116.65.32
loadaddr=0x10000000
netdev=eth0
netmask=255.255.255.0
nfsboot=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath
ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off
console=$consoledev,$baudrate $othbootargs;tftp $loadaddr
$bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr - $fdtaddr
ramboot=setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate
$othbootargs;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr
$bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr
ramdiskaddr=0x02000000
ramdiskfile=t4240qds/ramdisk.uboot
rootpath=/opt/nfsroot
serverip=10.116.65.38
stderr=serial
stdin=serial
stdout=serial
tftpflash=tftpboot $loadaddr $uboot && protect off $ubootaddr+$filesize && erase $ubootaddr +$filesize && cp.b $loadaddr $ubootaddr $filesize && protect on $ubootaddr +$filesize && cmp.b $loadaddr $ubootaddr $filesize
uboot="u-boot.bin"
ubootaddr=0xeff80000
Environment size: 1564/8188 bytes
There are a few variables that you need to modify, and they are:
$bootfile – file that is used as a kernel to boot
$fdtfile – the device tree file specific to the T4240 from the yocto build
$loadaddr – The temporary RAM address to which the kernel is loaded temporarily before being loadedinto the working memory space
$fdtaddr – The temporary RAM address to which the device tree is loaded temporarily
$bootargs – The boot argument that sets the root parameter to denote where the root filesystem is to be looked for and other variables such as baudrate etc.
The values that I set are specific to the files I built, but other variables are common.
The $loadaddr should hold a value 0x10000000
The $fdtaddr should hold a value 0x17200000
To set the values :
=> editenv boot file
edit: uImage
=> editenv fdtfile
edit: uImage-t4240qds.dtb
=> editenv loadaddr
edit: 0x10000000
=> editenv fdtaddr
edit: 0x17200000
=> savenenv
Now go ahead and boot the machine, with:
=> setenv bootargs root=/dev/mmcblk0p1 rw rootdelay=5 console=$consoledev,$baudrate;mmcinfo;ext2load mmc 0:1 $loadaddr $bootfile;ext2load mmc 0:1 $fdtaddr $fdtfile; bootm $loadaddr - $fdtaddr
(( Note: Break down of the above command:
The previous command sets the location of the root filesystem, in this case, it is the MMC card, /dev/mmcblk0p1
=> mmcinfo
The above command prints out the details of the MMC card
=> ext2load mmc 0:1 $loadaddr $bootfile
The above command reads the kernel image from the filesystem to the temporary RAM address for the machine to boot
=> ext2load mmc 0:1 $fdtaddr $fdtfile;
The above command reads the fdtfile into RAM memory
=> bootm $loadaddr - $fdtaddr
The above command issues the boot command with kernel addresses and fdt address as inputs
Here the “root=” variable sets the device ID of the root filesystem and ext2load reads a file from an ext2 filesystem.The boot proceeds and then you see a login prompt with…
INIT: Entering runlevel: 5 Starting Dropbear SSH server: dropbear.
Starting network benchmark server: netserver.
Starting system log daemon...0
Starting kernel log daemon...0
Stopping Bootlog daemon: bootlogd.
Poky 9.0 (Yocto Project 1.4 Reference Distro) 1.4 t4240qds ttyS0
t4240qds login:
Go ahead and login!
t4240qds login: root
root@t4240qds:~#
You can verify that the build works with
root@t4240qds:~# uname -a
Linux t4240qds 3.8.13-rt9-QorIQ-SDK-V1.4 #1 SMP Tue Feb 18 12:26:03 IST 2014 ppc64 GNU/Linux
The build date shows the date the image was built! If you have included the htop GNU package into the root filesystem, you can test it out.
root@t4240qds:~# htop
This opens the htop application!!
Comments
This is out of date. The links for the sdk downloads are dead. NXP has a QorIQ-SDK-V1.4-Source.iso that may or may not be the same as QorIQ Linux SDK v1.4 Yocto Source ISO referenced in the article. If anyone can tell me if these files are the same or not, please do.
The newest version of yocto (2.0) seems to have a different folder structure, command list and I could not follow tut with yocto linux sdk 2.0.
Followed tut with QorIQ-SDK-V1.4-Source.iso. Got to bitbake and this happened:
whampt@whampt:/home/yocto/build_t4240qds_release$ bitbake fsl-image-core
Pseudo is not present but is required, building this first before the main build
WARNING: Host distribution "CentOS-7.2.1511" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |#################################################################################################################################| ETA:  00:00:00
Loaded 1154 entries from dependency cache.
ERROR: No recipes available for:
  /home/yocto/meta-fsl-ppc/recipes-devtools/tclap/tclap_1.2.1.bbappend
ERROR: Command execution failed: Exited with 1
please help me figure this out. thanks
No ratings
Version history
Last update:
‎03-01-2014 06:01 AM
Updated by:
