L1 D-Cache Flushing
L1 D-Cache Flushing
L1 D-Cache Flushing
Recently I was handling a problem of E500 Data Cache flush. I have a study on this. Below is a summary/record of the study, here to post it for someone who may be interested in.
1. L1 D-Cache Flushing
About Data Cache flush, there’s some description in E500 reference manual as below:
Any modified entries in the data cache can be copied back to memory (flushed) by using a dcbf instruction or by executing a series of 12 uniquely addressed load or dcbz instructions to each of the 128 sets. The address space should not be shared with any other process to prevent snoop hit invalidations during the flushing routine. Exceptions should be disabled during this time so that the PLRU algorithm is not disturbed.
The following methods can be used to flush a region in the L1 cache:
• Perform reads to any 48-Kbyte region, then execute dcbf instructions to that region. Note that a 48-Kbyte region must be used to ensure that the PLRU algorithm flushes all of the cache entries (12 x 128 sets x 32 bits = 48 Kbytes).
• Perform reads from any 48-Kbyte region that is guaranteed to not be modified in the L1 cache (for example, a ROM region).
• Execute dcbz instructions to any 48-Kbyte scratch section, then invalidate the cache. Note that it is necessary to use a scratch region because some zeroed lines will be cast out.
On the e500v2 the HID0 register contains a field, DCFA (data cache flush assist), that, when set, forces the data cache to ignore invalid sets on miss replacement selection and follow the replacement sequence defined by the PLRU bits. This reduces the series of uniquely addressed load or dcbz instructions to eight per set. The bit should be set just before beginning a cache flush routine and should be cleared when the series of instructions is complete.
2. The Questions
As the Data Cache size is 32 Kbytes, why 48 Kbytes region needs to be performed on? The manual uses an equation “12 x 128 sets x 32 bytes = 48 Kbytes” (here I assume it should be 32 bytes instead of 32 bits), it says a series of 12 uniquely addressed load to each of the 128 sets, but there is no explanation why it’s 12, and why uniquely?
And more, it mentions the HID0 register filed DCFA. It says setting this field reduces the series of uniquely addressed load to eight per set. Why? This time there are more words “forces the data cache to ignore invalid sets on miss replacement selection and follow the replacement sequence defined by the PLRU bits”, how to understand?
3. Data Cache Basics
To answer the questions above, we need to focus on the miss replacement selection algorithm as it refers to. But before this we should be clear about the Data Cache organization first, and know the “invalid sets” status.
The E500 reference manual use below figure to describe the L1 D-Cache organization
From this figure, we get 128 sets, 8 ways per set, and 32 bytes per way, which is 128 x 8 x 32 = 32 Kbytes. Here a block, also called a line/way, contains 8 words, or 32 bytes.
Where a piece of data in memory should be placed into D-Cache? In other words what’s the mapping method between memory and the Cache?
Each block is loaded from 8-words boundary, i.e. physical address bits PA[27:31] are zeros. Byte within a block is located by PA[27:31].
The set is selected by physical address bits PA[20:26], totally 27 =128, there is one set for each PA[20:26], or we say it’s one to one mapping.
The tags consist of physical address bit PA[0:19], there are totally 220 kinds of tags but there are only 8 ways in each set, it’s one to multiple mapping. So we need replacement algorithm, in e500 the PLRU (pseudo-least-recently-used) replacement algorithm is used.
4. Miss Replacement
In the reference manual it says “This algorithm prioritizes the replacement of invalid entries over valid ones (starting with way 0). Otherwise, if all ways are valid, one is selected for replacement according to the PLRU bit encodings shown in Table 11-8.”
This is where the difference happened. Let’s analyze the easy case first, if HID0 register filed DCFA is set, all the ways are treated the same, valid or invalid will be ignored, only PLRU take effect. Assume PLRU bits are all zeros, below table shows the order ways be selected:
B0
B1
B2
B3
B4
B5
B6
Ways selected
0
0
0
0
0
0
0
L0
1
1
1
0
0
0
0
L4
0
1
1
0
0
1
0
L2
1
0
1
0
1
1
0
L6
0
0
0
0
1
1
1
L1
1
1
0
0
1
1
1
L5
0
1
1
0
1
0
1
L3
1
0
1
0
0
0
1
L7
After 8 replacements, all the 8 ways are selected. Change PLRU bits to other values it’s still 8 replacements, that’s way it reduce 12 uniquely addressed load to 8.
Then why it’s 12 if DCFA field is not set? Assume way 0,1,2,3 are invalid and way 4,5,6,7 are valid, and PLRU bits are all zeros, we have again the table as below:
B0
B1
B2
B3
B4
B5
B6
Ways selected
0
0
0
0
0
0
0
L0
1
1
0
1
0
0
0
L1
1
1
0
0
0
0
0
L2
1
0
0
0
1
0
0
L3
1
0
0
0
0
0
0
L4
0
0
1
0
0
1
0
L0
1
1
1
1
0
1
0
L6
0
1
0
1
0
1
1
L2
1
0
0
1
1
1
1
L5
0
0
1
1
1
0
1
L1
1
1
1
0
1
0
1
L7
After 11 replacements, all the 8 ways are selected. Assume way 0,1,2,3,6,7 are invalid and way 4,5 are valid, and PLRU B5 is zero, we have again the table as below:
B0
B1
B2
B3
B4
B5
B6
Ways selected
0
L0
1
1
1
0
L1
1
1
0
0
L2
1
0
0
1
0
L3
1
0
0
0
0
L6
0
0
0
0
0
0
1
L7
0
0
0
0
0
0
0
L0
1
1
1
0
0
0
0
L4
0
1
1
0
0
1
0
L2
1
0
1
0
1
1
0
L6
0
0
0
0
1
1
1
L1
1
1
0
0
1
1
1
L5
After 12 replacements, all the 8 ways are selected. Here 12 is the maximum replacement number, any other case will finish all 8 ways selected within 12 replacements.
There are Cache operation code examples in NCSW for e500, including L1 D-Cache flushing, as attached. Also the whole article in attached as individual document.
%3CLINGO-SUB%20id%3D%22lingo-sub-1118646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EL1%20D-Cache%20Flushing%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ERecently%20I%20was%20handling%20a%20problem%20of%20E500%20Data%20Cache%20flush.%20I%20have%20a%20study%20on%20this.%20Below%20is%20a%20summary%2Frecord%20of%20the%20study%2C%20here%20to%20post%20it%20for%20someone%20who%20may%20be%20interested%20in.%3C%2FP%3E%3CH1%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId-381652720%22%20id%3D%22toc-hId-1296888999%22%3E1.%20L1%20D-Cache%20Flushing%3C%2FH1%3E%3CP%3EAbout%20Data%20Cache%20flush%2C%20there%E2%80%99s%20some%20description%20in%20E500%20reference%20manual%20as%20below%3A%3C%2FP%3E%3CP%3E%3CEM%3EAny%20modified%20entries%20in%20the%20data%20cache%20can%20be%20copied%20back%20to%20memory%20(flushed)%20by%20using%20a%20dcbf%20instruction%20or%20by%20executing%20a%20series%20of%2012%20uniquely%20addressed%20load%20or%20dcbz%20instructions%20to%20each%20of%20the%20128%20sets.%20The%20address%20space%20should%20not%20be%20shared%20with%20any%20other%20process%20to%20prevent%20snoop%20hit%20invalidations%20during%20the%20flushing%20routine.%20Exceptions%20should%20be%20disabled%20during%20this%20time%20so%20that%20the%20PLRU%20algorithm%20is%20not%20disturbed.%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EThe%20following%20methods%20can%20be%20used%20to%20flush%20a%20region%20in%20the%20L1%20cache%3A%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E2%80%A2%20Perform%20reads%20to%20any%2048-Kbyte%20region%2C%20then%20execute%20dcbf%20instructions%20to%20that%20region.%20Note%20that%20a%2048-Kbyte%20region%20must%20be%20used%20to%20ensure%20that%20the%20PLRU%20algorithm%20flushes%20all%20of%20the%20cache%20entries%20(12%20x%20128%20sets%20x%2032%20bits%20%3D%2048%20Kbytes).%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E2%80%A2%20Perform%20reads%20from%20any%2048-Kbyte%20region%20that%20is%20guaranteed%20to%20not%20be%20modified%20in%20the%20L1%20cache%20(for%20example%2C%20a%20ROM%20region).%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E2%80%A2%20Execute%20dcbz%20instructions%20to%20any%2048-Kbyte%20scratch%20section%2C%20then%20invalidate%20the%20cache.%20Note%20that%20it%20is%20necessary%20to%20use%20a%20scratch%20region%20because%20some%20zeroed%20lines%20will%20be%20cast%20out.%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%E2%80%A6%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3EOn%20the%20e500v2%20the%20HID0%20register%20contains%20a%20field%2C%20DCFA%20(data%20cache%20flush%20assist)%2C%20that%2C%20when%20set%2C%20forces%20the%20data%20cache%20to%20ignore%20invalid%20sets%20on%20miss%20replacement%20selection%20and%20follow%20the%20replacement%20sequence%20defined%20by%20the%20PLRU%20bits.%20This%20reduces%20the%20series%20of%20uniquely%20addressed%20load%20or%20dcbz%20instructions%20to%20eight%20per%20set.%20The%20bit%20should%20be%20set%20just%20before%20beginning%20a%20cache%20flush%20routine%20and%20should%20be%20cleared%20when%20the%20series%20of%20instructions%20is%20complete.%3C%2FEM%3E%3C%2FP%3E%3CH1%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId--1425801743%22%20id%3D%22toc-hId--510565464%22%3E2.%20The%20Questions%3C%2FH1%3E%3CP%3EAs%20the%20Data%20Cache%20size%20is%2032%20Kbytes%2C%20why%2048%20Kbytes%20region%20needs%20to%20be%20performed%20on%3F%20The%20manual%20uses%20an%20equation%20%E2%80%9C%3CEM%3E12%20x%20128%20sets%20x%2032%20bytes%20%3D%2048%20Kbytes%3C%2FEM%3E%E2%80%9D%20(here%20I%20assume%20it%20should%20be%2032%20bytes%20instead%20of%2032%20bits)%2C%20it%20says%20a%20series%20of%2012%20uniquely%20addressed%20load%20to%20each%20of%20the%20128%20sets%2C%20but%20there%20is%20no%20explanation%20why%20it%E2%80%99s%2012%2C%20and%20why%20uniquely%3F%3C%2FP%3E%3CP%3EAnd%20more%2C%20it%20mentions%20the%20HID0%20register%20filed%20DCFA.%20It%20says%20setting%20this%20field%20reduces%20the%20series%20of%20uniquely%20addressed%20load%20to%20eight%20per%20set.%20Why%3F%20This%20time%20there%20are%20more%20words%20%E2%80%9C%3CEM%3Eforces%20the%20data%20cache%20to%20ignore%20invalid%20sets%20on%20miss%20replacement%20selection%20and%20follow%20the%20replacement%20sequence%20defined%20by%20the%20PLRU%20bits%3C%2FEM%3E%E2%80%9D%2C%20how%20to%20understand%3F%3C%2FP%3E%3CH1%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId-1061711090%22%20id%3D%22toc-hId-1976947369%22%3E3.%20Data%20Cache%20Basics%3C%2FH1%3E%3CP%3ETo%20answer%20the%20questions%20above%2C%20we%20need%20to%20focus%20on%20the%20miss%20replacement%20selection%20algorithm%20as%20it%20refers%20to.%20But%20before%20this%20we%20should%20be%20clear%20about%20the%20Data%20Cache%20organization%20first%2C%20and%20know%20the%20%E2%80%9Cinvalid%20sets%E2%80%9D%20status.%3C%2FP%3E%3CP%3EThe%20E500%20reference%20manual%20use%20below%20figure%20to%20describe%20the%20L1%20D-Cache%20organization%3C%2FP%3E%3CP%3EFrom%20this%20figure%2C%20we%20get%20128%20sets%2C%208%20ways%20per%20set%2C%20and%2032%20bytes%20per%20way%2C%20which%20is%20128%20x%208%20x%2032%20%3D%2032%20Kbytes.%20Here%20a%20block%2C%20also%20called%20a%20line%2Fway%2C%20contains%208%20words%2C%20or%2032%20bytes.%3C%2FP%3E%3CP%3EWhere%20a%20piece%20of%20data%20in%20memory%20should%20be%20placed%20into%20D-Cache%3F%20In%20other%20words%20what%E2%80%99s%20the%20mapping%20method%20between%20memory%20and%20the%20Cache%3F%3C%2FP%3E%3CP%3EEach%20block%20is%20loaded%20from%208-words%20boundary%2C%20i.e.%20physical%20address%20bits%20PA%5B27%3A31%5D%20are%20zeros.%20Byte%20within%20a%20block%20is%20located%20by%20PA%5B27%3A31%5D.%3C%2FP%3E%3CP%3EThe%20set%20is%20selected%20by%20physical%20address%20bits%20PA%5B20%3A26%5D%2C%20totally%202%3CSUP%3E7%20%3C%2FSUP%3E%3D128%2C%20there%20is%20one%20set%20for%20each%20PA%5B20%3A26%5D%2C%20or%20we%20say%20it%E2%80%99s%20one%20to%20one%20mapping.%3C%2FP%3E%3CP%3EThe%20tags%20consist%20of%20physical%20address%20bit%20PA%5B0%3A19%5D%2C%20there%20are%20totally%202%3CSUP%3E20%3C%2FSUP%3E%20kinds%20of%20tags%20but%20there%20are%20only%208%20ways%20in%20each%20set%2C%20it%E2%80%99s%20one%20to%20multiple%20mapping.%20So%20we%20need%20replacement%20algorithm%2C%20in%20e500%20the%20PLRU%20(pseudo-least-recently-used)%20replacement%20algorithm%20is%20used.%3C%2FP%3E%3CH1%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId--745743373%22%20id%3D%22toc-hId-169492906%22%3E4.%20Miss%20Replacement%3C%2FH1%3E%3CP%3EIn%20the%20reference%20manual%20it%20says%20%E2%80%9CThis%20algorithm%20prioritizes%20the%20replacement%20of%20invalid%20entries%20over%20valid%20ones%20(starting%20with%20way%200).%20Otherwise%2C%20if%20all%20ways%20are%20valid%2C%20one%20is%20selected%20for%20replacement%20according%20to%20the%20PLRU%20bit%20encodings%20shown%20in%20%3CSPAN%20style%3D%22color%3A%20%230000c3%3B%22%3ETable%2011-8%3C%2FSPAN%3E.%E2%80%9D%3C%2FP%3E%3CP%3EThis%20is%20where%20the%20difference%20happened.%20Let%E2%80%99s%20analyze%20the%20easy%20case%20first%2C%20if%20HID0%20register%20filed%20DCFA%20is%20set%2C%20all%20the%20ways%20are%20treated%20the%20same%2C%20valid%20or%20invalid%20will%20be%20ignored%2C%20only%20PLRU%20take%20effect.%20Assume%20PLRU%20bits%20are%20all%20zeros%2C%20below%20table%20shows%20the%20order%20ways%20be%20selected%3A%3C%2FP%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20style%3D%22border%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3EB0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3EB1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3EB2%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3EB3%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3EB4%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3EB5%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3EB6%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3EWays%20selected%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL0%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL4%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL2%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL6%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL1%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL5%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL3%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL7%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3EAfter%208%20replacements%2C%20all%20the%208%20ways%20are%20selected.%20Change%20PLRU%20bits%20to%20other%20values%20it%E2%80%99s%20still%208%20replacements%2C%20that%E2%80%99s%20way%20it%20reduce%2012%20uniquely%20addressed%20load%20to%208.%3C%2FP%3E%3CP%3EThen%20why%20it%E2%80%99s%2012%20if%20DCFA%20field%20is%20not%20set%3F%20Assume%20way%200%2C1%2C2%2C3%20are%20invalid%20and%20way%204%2C5%2C6%2C7%20are%20valid%2C%20and%20PLRU%20bits%20are%20all%20zeros%2C%20we%20have%20again%20the%20table%20as%20below%3A%3C%2FP%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20style%3D%22border%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EB0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EB1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EB2%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EB3%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EB4%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EB5%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EB6%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EWays%20selected%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL0%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL1%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL2%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL3%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL4%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL0%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL6%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL2%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL5%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL1%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL7%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3EAfter%2011%20replacements%2C%20all%20the%208%20ways%20are%20selected.%20Assume%20way%200%2C1%2C2%2C3%2C6%2C7%20are%20invalid%20and%20way%204%2C5%20are%20valid%2C%20and%20PLRU%20B5%20is%20zero%2C%20we%20have%20again%20the%20table%20as%20below%3A%3C%2FP%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%220%22%20cellspacing%3D%220%22%20style%3D%22border%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EB0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EB1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EB2%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EB3%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EB4%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EB5%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EB6%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-left%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EWays%20selected%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL0%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL1%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL2%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL3%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E-%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL6%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL7%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL0%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL4%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL2%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL6%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL1%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20windowtext%201.0pt%3B%20border-top%3A%20none%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E0%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%2237%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3E1%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%20solid%20windowtext%201.0pt%3B%20border-right%3A%20solid%20windowtext%201.0pt%3B%20padding%3A%200%205.4pt%200%205.4pt%3B%22%20valign%3D%22top%22%20width%3D%22107%22%3E%3CP%20align%3D%22center%22%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20center%3B%22%3EL5%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3EAfter%2012%20replacements%2C%20all%20the%208%20ways%20are%20selected.%20Here%2012%20is%20the%20maximum%20replacement%20number%2C%20any%20other%20case%20will%20finish%20all%208%20ways%20selected%20within%2012%20replacements.%3C%2FP%3E%3CP%3EThere%20are%20Cache%20operation%20code%20examples%20in%20NCSW%20for%20e500%2C%20including%20L1%20D-Cache%20flushing%2C%20as%20attached.%20Also%20the%20whole%20article%20in%20attached%20as%20individual%20document.%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎12-29-2015 12:20 AM
Updated by:
