The NCSW - NetComm Software - is a package to help speed development on Freescale PowerQUICC and QorIQ processor platforms. It contains NCDD - NetComm Device Drivers - and some other components. Here take P3041 I2C supported in version GA_4.7 as an example to analyze the NetComm Software structure and device driver usage. CW PA 10.3 is used to be compatible for the use case code.
