error in compiling yocto Ubuntu 12.04
longzhao
Dear ;
i am sorry to truble you,I am a newbie,when i compilering  a core image :  $bitbake fsl-image-machine-test
ubuntu:12.04
the version:3.14.28-1.0
here is my Installation documentation:
A)
  1.
  $ mkdir ~/bin (this step may not be needed if the bin folder already exists)
  $ git clone https://gerrit-google.tuna.tsinghua.edu.cn/git-repo
  $ cp git-repo/repo ~/bin/repo
  $ chmod a+x ~/bin/repo
  2. export PATH=~/bin:$PATH
B)
$ git config --global user.name "zhaolong"
$ git config --global user.email "[email protected]"
$ git config --list
$ mkdir fsl-release-bsp
$ cd fsl-release-bsp
$ repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-3.14.52-1.1.0_ga --repo-url=https://gerrit-google.tuna.tsinghua.edu.cn/git-repo
$ repo sync
C)
MACHINE=imx6qsabresd source fsl-setup-release.sh -b imx6qsabresd-fb -e fb
there is the following error while running ;
Traceback (most recent call last):
  File "/usr/bin/bitbake", line 234, in <module>
    ret = main()
  File "/usr/bin/bitbake", line 197, in main
    server = ProcessServer(server_channel, event_queue, configuration)
  File "/usr/lib/pymodules/python2.7/bb/server/process.py", line 78, in __init__
    self.cooker = BBCooker(configuration, self.register_idle_function)
  File "/usr/lib/pymodules/python2.7/bb/cooker.py", line 76, in __init__
    self.parseConfigurationFiles(self.configuration.file)
  File "/usr/lib/pymodules/python2.7/bb/cooker.py", line 510, in parseConfigurationFiles
    data = _parse(os.path.join("conf", "bitbake.conf"), data)
TypeError: getVar() takes exactly 3 arguments (2 given)
ERROR: Error evaluating '${TARGET_OS}:${TRANSLATED_TARGET_ARCH}:build-${BUILD_OS}:pn-${PN}:${MACHINEOVERRIDES}:${DISTROOVERRIDES}:${CLASSOVERRIDE}:forcevariable'
  File "/usr/lib/pymodules/python2.7/bb/data_smart.py", line 116, in expandWithRefs
    s = __expand_var_regexp__.sub(varparse.var_sub, s)
  File "/usr/lib/pymodules/python2.7/bb/data_smart.py", line 60, in var_sub
    var = self.d.getVar(key, 1)
  File "/usr/lib/pymodules/python2.7/bb/data_smart.py", line 260, in getVar
    return self.expand(value, var)
  File "/usr/lib/pymodules/python2.7/bb/data_smart.py", line 132, in expand
    return self.expandWithRefs(s, varname).value
  File "/usr/lib/pymodules/python2.7/bb/data_smart.py", line 117, in expandWithRefs
    s = __expand_python_regexp__.sub(varparse.python_sub, s)
ERROR: Error evaluating '${@bb.parse.BBHandler.vars_from_file(d.getVar('FILE'),d)[0] or 'defaultpkgname'}'
  File "/usr/lib/pymodules/python2.7/bb/data_smart.py", line 76, in python_sub
    value = utils.better_eval(codeobj, DataContext(self.d))
  File "/usr/lib/pymodules/python2.7/bb/utils.py", line 387, in better_eval
    return eval(source, _context, locals)
  File "PN", line 1, in <module>
Thanks;
zhaolong;
Pavel
We usually use the following command sequence for SDK installing under Ubuntu 14.04 or 12.04:
  1. 1. sudo apt-get install ubuntu-minimal ubuntu-standard patch vim-common sed wget subversion git-core coreutils libbonobo2-common unzip texi2html texinfo libsdl1.2-dev docbook-utils gawk python-pysqlite2 diffstat make gcc build-essential xz-utils g++ desktop-file-utils chrpath libgl1-mesa-dev libglu1-mesa-dev autoconf automake groff libtool xterm libncurses5-dev cvs tofrodos
  1. 2.  a) command: ls -l /bin/sh
                Message:  /bin/sh -> dash
    b) command: sudo dpkg-reconfigure dash
                Answer after password – No
                Message:
                Removing 'diversion of /bin/sh to /bin/sh.distrib by dash'
                Adding 'diversion of /bin/sh to /bin/sh.distrib by bash'
                Removing 'diversion of /usr/share/man/man1/sh.1.gz to /usr/share/man/man1/sh.distrib.1.gz by dash'
                Adding 'diversion of /usr/share/man/man1/sh.1.gz to /usr/share/man/man1/sh.distrib.1.gz by bash'
    c) command for checking: ls -l /bin/sh
                Message: /bin/sh -> bash
  1. 3. install SDK for your core
  2. 4. install SDK source
  3. 5. cd <sdk-install-dir>.
  4. 6. ./sources/meta-freescale/scripts/host-prepare.sh
Usually Linux recommends also run the following command: sudo usr/sbin/visudo
Pavel Chubakov
longzhao
thanks
