Writing code in Java with BSC9131
eliranroffe
I consider using BSC9131 with CodeWarrior.
I saw that it is possible write my code only on C and C++.
Is it possible to wirte my code on Java, compile it with CodeWarrrior and run the application On the BSC9131? What suppose to be the performance degredation
Thanks!
lunminliang
After discussing with colleagues, we think there are three ways:
