tpcip_middleware error in Processor Expert Problem
chen1834
Hi all,
Can you help to explain the reason of the error below and how to fix?
IDE Version is 2017.R1
Compling results in 2 errors:
Description Resource Path Location Type
ERROR: TCPIP stack has been validated with gcc. compiler is not supported. DRIVE11GB_ACon_wit tcpip_middleware Processor Expert Problem
ERROR: Unexpected status of script: Beans\tcpip\tcpip_common.chg, please contact Freescale support. DRIVE11GB_ACon_wit tcpip_middleware Processor Expert Problem
Thank you!
lukaszadrapa
Hi Chen,
which compiler do you use? Is that gcc or any other?
By the way, the latest S32DS version is 2.1 and latest version of SDK is 3.0.3.
Lukas
chen1834
gcc is used.
By the way, how can I easily get to know about the diffs of the two SDK version and the two IDE version?
lukaszadrapa
There are Release Notes files for both S32DS IDE and also for SDK packages. You can find them in installation folder.
ZhangJennie
Hi chen1834
Please let us know your chip part number. Thus we can assign right engineer for your problem.
Jun Zhang
chen1834
It is MPC 5748G.
SDK: S32_SDK_MPC574xx_RTM_1.0.0
