i.mx8 ddr bandwidth pmu
964件の閲覧回数
oferh
I am want to measure the CPU`s DDR access during a benchmark test, the results should be for a predefined test duration how many bytes were read and written to DDR.
There are several counters I saw in the PMU that may be relevant but I could not find the description of the PMU counters in the i.MX8 spec.
Is there some additional spec that describes the PMU counters?
Is there a way to perform the DDR usage?
/Ofer
0 返答(返信)
