i.MX 8QuadXplus
i.MX 8QuadXplus
Chethanbg
We are using MiMX8QX6AVLFZAC in our custom board,we wanted to download Linux image but in below link we are seeing i.MX 8QuadXplus (C0) and  i.MX 8QuadXplus (B0) images what is the difference between C0 and B0 how can we find which version to download and use?
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
JorgeCas
That revision is related with the MEK board not the IC, if you based your design with some specific MEK board revision, I recommend use the same BSP image revision.
Best regards.
