how to set PWM as center aligned ?
2,944 次查看
hotashu
I use K40 with processor expert, PWM_LDD bean. it seems no place to set it as center aligned. how to do this ?
hotas
4 回复数
2,236 次查看
sergigomis
Hello.
You can program the registers directly.
1st.  Configure the Processor Expert PWM.
2on. After Processor Expert Initialitzation  "PE_low_level_init();", set this code:
FTM0_MODE |= 1<<2;           // Write Protection Disable (1)
FTM0_SC |= 1<<5;                // Center Aligned PWM  CPWMS=1
FTM0_MODE &= 1<<2;        // Write Protection Enable (0)
This code works for me on K22.
Change FTMx to used Timer.
Regards.
2,236 次查看
vfilip
Hello, I have got info from developers that this component does not provide such feature and in case you need this feature please use corresponding initialization component + PDD macros.
Anyway, it would very helpful for us if you could provide more details about your project.
best regards
Vojtech Filip
Processor Expert Support Team
2,236 次查看
hotashu
Hi Filip,
i never used PDD before. is there any sample on how to use PDD macro?
2,236 次查看
vfilip
I would recommend to download CW V10.4 and follow the steps within this thread: How to use PDD macros in CW V10.4 step by step
Best Regard
Vojtech Filip
