fsl_rtc... Why do not save time?
1,156件の閲覧回数
holyhope
Hi to all.
I'm developing on K20; I use KDS 2.0.0
I use the RTC_LDD component for Real-Time-Clock without using KSDK (for K20 KSDK is not ready yet...).
I set via the time via my Firmware and I turn off my device for two days.... and turn on... It give me the correct date and time!
Now I try to use KSDK 1.1.0 setting K60 uP instead K20; all seems work correctly but fsl_rtc component don't work well...
For the first thing I see that If i do not explicit do this instruction:
    uint32_t rtcBaseAddr = g_rtcBaseAddr[FSL_RTCTIMER1];
    RTC_HAL_EnableCounter(rtcBaseAddr, true);
the automatic init procedure do not enable it automatically.
The second (and very big problem....) is that if I turn off and turn on my device it will lost my time!
I suppose that this component do not work right... what I can do for preserve my time during turn off?
Many thanks,
Massimiliano
829件の閲覧回数
maheshmahadeva1
The issue of RTC not retaining its time is fixed in the upcoming KSDK 1.2 release, the problem was identified to a reset call issued in the HAL_Init function. Below is a patch that could be applied to the KSDK 1.1 RTC driver to fix this issue.
diff --git a/platform/hal/src/rtc/fsl_rtc_hal.c b/platform/hal/src/rtc/fsl_rtc_hal.c
index 905b59d..8fc188c 100644
--- a/platform/hal/src/rtc/fsl_rtc_hal.c
+++ b/platform/hal/src/rtc/fsl_rtc_hal.c
@@ -263,15 +263,15 @@ void RTC_HAL_Disable(uint32_t rtcBaseAddr)
void RTC_HAL_Init(uint32_t rtcBaseAddr)
-    uint32_t seconds = 0x1;
-    /* Resets the RTC registers except for the SWR bit */
-    RTC_HAL_SoftwareReset(rtcBaseAddr);
-    RTC_HAL_SoftwareResetFlagClear(rtcBaseAddr);
-    /* Set TSR register to 0x1 to avoid the TIF bit being set in the SR register */
-    RTC_HAL_SetSecsReg(rtcBaseAddr, seconds);
+    if(BR_RTC_SR_TIF(rtcBaseAddr))
+        /* Resets the RTC registers except for the SWR bit */
+        RTC_HAL_SoftwareReset(rtcBaseAddr);
+        RTC_HAL_SoftwareResetFlagClear(rtcBaseAddr);
+        /* Set TSR register to 0x1 to avoid the TIF bit being set in the SR register */
+        RTC_HAL_SetSecsReg(rtcBaseAddr, 1U);
     /* Clear the interrupt enable register */
     RTC_HAL_SetSecsIntCmd(rtcBaseAddr, false);
     RTC_HAL_SetAlarmIntCmd(rtcBaseAddr, false);
2 返答(返信)
830件の閲覧回数
maheshmahadeva1
829件の閲覧回数
holyhope
Ok many thanks!
Massimiliano
