connection problem
connection problem
hande
First of all, I am not sure I choosed correct location. I have SEN-SPI-BOX and I downloaded FFV tool. when I connect my kit to my computer, I get "no device found" message. But before I could connect directly. I didn't change anything.I tried it another computer but result was same. Why I can not connect? What I should do?
Thank in advance.
hande
Hello David,
Thanks for quick feedback. I am using Windows. I reflashed my kit with using SD card and I solved the problem.
Thanks for your support.
diazmarin09
I hope all is great with you. Thank you for using the NXP communities.
Could you please confirm the OS that you are using? I mean, are you using Windows?
David
hande
Hello David,
