codewarrior5.1
codewarrior5.1
刘莫焊
我购买了codewarrior5.1版本的软件,但是光盘下载出来还是有代码长度32KB 的限制,是怎么回事呢?这个代码长度限制应该怎么解决?
ZhangJennie
@刘莫焊
你好!光盘上里的安装文件是Code Warrior Special版本, 有32K代码限制。
如果购买了license,应该有一个CodeWarrior的注册码(registration code), 用这个注册码在官网激活获得一个license。把这个license安装到CodeWarrior的安装路径下就可以去掉CodeWarrior的代码限制。
Jun Zhang
ZhangJennie
@刘莫焊
Jun Zhang
刘莫焊
你好,因为这个是之前师兄买的说是之前肯定没得问题的,但我不太清楚各种资源位置,我想问一下意思是光盘里本身里面是没有license的吗?有购买了license的话,这个注册码是在哪里查询的呢,是在购买的账号吗还是光盘里有呢?
ZhangJennie
对的,光盘里是通用的CodeWarrior 安装文件,不包括注册码。
注册码是一串序列号,你问一下当初购买CodeWarrior的人,他应该知道。
%3CLINGO-SUB%20id%3D%22lingo-sub-2150511%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3Ecodewarrior5.1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150511%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%3EI%20purchased%20%3CSPAN%3Ecodewarrior%205.1%2C%20but%20there%20is%20still%20a%20code%20length%20limit%20of%2032KB%20on%20the%20CD-ROM%20download.%20What%20should%20I%20do%20to%20solve%20this%20code%20length%20limitation%3F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151439%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20codewarrior5.1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151439%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EYes%2C%20the%20CD-ROM%20contains%20the%20generic%20CodeWarrior%20installation%20files%20and%20does%20not%20include%20the%20registration%20code.%3C%2FP%3E%0A%3CP%3EThe%20registration%20code%20is%20a%20string%20of%20serial%20numbers%2C%20ask%20the%20person%20who%20bought%20CodeWarrior%20in%20the%20first%20place%2C%20he%20should%20know.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150772%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20codewarrior5.1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150772%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EHello%2C%20because%20this%20is%20the%20previous%20brother%20to%20buy%20that%20is%20certainly%20no%20problem%20before%2C%20but%20I'm%20not%20too%20clear%20about%20the%20location%20of%20the%20various%20resources%2C%20I%20would%20like%20to%20ask%20means%20that%20the%20CD-ROM%20itself%20inside%20is%20not%20license%3F%20If%20there%20is%20a%20license%20purchased%2C%20where%20is%20the%20registration%20code%20to%20check%2C%20is%20it%20in%20the%20purchased%20account%20or%20is%20it%20in%20the%20CD-ROM%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150692%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20codewarrior5.1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150692%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253713%22%20target%3D%22_blank%22%3E%40LiuMoWelding%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3EHello.%20The%20installation%20file%20on%20the%20CD-ROM%20is%20Code%20Warrior%20Special!%20The%20installation%20file%20on%20the%20CD%20is%20Code%20Warrior%20Special%2C%20which%20has%20a%2032K%20code%20limit.%3C%2FP%3E%0A%3CP%3EIf%20you%20have%20purchased%20a%20license%2C%20you%20should%20have%20a%20CodeWarrior%20registration%20code%2C%20use%20it%20to%20activate%20the%20license%20on%20the%20official%20website%2C%20and%20install%20the%20license%20in%20the%20installation%20path%20of%20CodeWarrior%20to%20remove%20the%20code%20restrictions%20of%20CodeWarrior.%3C%2FP%3E%0A%3CP%3EJun%20Zhang%3C%2FP%3E%3C%2FLINGO-BODY%3E
