Processor Expert 10.4 and KEA
jimgulliver
I am trying to use Processor Expert to build some test code for a S9KEAZ128AMLH. After much fun learning how Processor Expert works (I use the term with wry humour), I get acouple of failure errors.
1...missing device header file
2...Message in build problems box
....code fails to build, due to missing header file for KEA device and then an error....
Type Generator: FAILURE: Unexpected status of script: Drivers\Common\SetRegBitMask.prg, please contact Freescale support.
Can anyone help please
t
Carlos_Mendoza
Hi Jim,
Which IDE are you using? Could you tell us the steps to reproduce these errors?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
