PCF85263A RTC issue
PCF85263A RTC issue
1,516件の閲覧回数
Thenmozhi
we are using external RTC PCF85263A for PIC32MM0256GPM064 microcontroller .we faced issues utilizing PCF85263A.
we tried to updated the time in RTC.it was successfull but the time is not incremented .
we changed the rtc.it was not work.
kindly suggest the solutions for RTC issue.
#include <xc.h>
#include <stdio.h>
#include <stdlib.h>
#define I2Cwrite     0xA2
#define I2CRead     0xA3
void I2C_wait_for_idle(void)
while(I2C3CON & 0x1F);
while(I2C3STATbits.TRSTAT);
void I2C_start()
I2C_wait_for_idle();
I2C3CONbits.SEN = 1;
while (I2C3CONbits.SEN == 1);
void I2C_stop()
I2C3CONbits.PEN = 1;
void I2C_restart()
I2C3CONbits.RSEN = 1;
while (I2C3CONbits.RSEN == 1);
void I2C_ack(void)
I2C3CONbits.ACKDT = 0;
I2C3CONbits.ACKEN = 1;
while(I2C3CONbits.ACKEN);
void I2C_nack(void)
I2C3CONbits.ACKDT = 1;
void I2c_write(unsigned char address, char wait_ack)
I2C3TRN = address | 0;
while (I2C3STATbits.TBF == 1);
if (wait_ack) while (I2C1STATbits.ACKSTAT == 1);
void I2c_read(unsigned char *value, char ack_nack)
I2C3CONbits.RCEN = 1;
while (I2C3CONbits.RCEN);
while (!I2C3STATbits.RBF);
*value = I2C3RCV;
if (!ack_nack)
I2C_ack();
else
I2C_nack();
void I2C_Initialize()
LATC = 0x00;
ANSELBbits.ANSB13 = 0;
TRISBbits.TRISB13 = 1;
TRISBbits.TRISB7 = 1;
I2C3CONbits.ON = 1;
I2C3CONbits.DISSLW = 1;
I2C3BRG = 7;
I2C3STAT = 0x0;
void PCF85263_write(unsigned char reg_address, unsigned char value)
I2C_start();
I2c_write(I2Cwrite , 1);
I2c_write(reg_address,1);
I2c_write(value,1);
I2C_stop();
void PCF85263_read(unsigned char reg_address, unsigned char *value)
I2C_start();
I2C_restart();
I2c_write( I2CRead ,1);
I2c_read(value, 1);
I2C_stop();
void rtc_read()
PCF85263_read(0x2E, &value);
PCF85263_read(0x28, &data);
PCF85263_read(0x01, &sec);
PCF85263_read(0x02, &min);
PCF85263_read(0x03, &hours);
PCF85263_read(0x04, &date);
PCF85263_read(0x05, &day);
PCF85263_read(0x06, &month);
PCF85263_read(0x07, &years);
void rtc_write()
PCF85263_write(0x2E, 0x01);
PCF85263_write(0x28, 0xA4);
PCF85263_write(0x01, 0x00);
PCF85263_write(0x02, 0x00);
PCF85263_write(0x03, 0x00);
PCF85263_write(0x04, 0x05);
PCF85263_write(0x05, 0x06);
PCF85263_write(0x06, 0x05);
PCF85263_write(0x07, 0x23);
PCF85263_write(0x2E, 0x00);
1,499件の閲覧回数
ErichStyger
Specialist I
I'm using the PCF85063A, but I thing your device is similar.
The CTRL register has a STOP bit which stops/disables the clock.
See for example my implementation here:
https://github.com/ErichStyger/McuOnEclipseLibrary/blob/master/lib/src/McuPCF85063A.c
So check your data sheet for a STOP bit and check the setting of this bit.
I hope this helps,
Erich
