P.E. TWR K70 BAREBOARD and STDIO REdirect
已解决
跳至解决方案
3,126 次查看
crezyoz
Working on my first of 3 projects for the K70. I have a P.E. project running and I have been able to use an Async Serial component to send data back to a terminal. Now I would like to redirect STDIO out as well. Currently, printf statmements do who up in a CodeWarrior terminal but I would like to redirect all stdio to any port I wish.
Been searching for this solution for a few hours.. coming up short. Could really use an assist here.
Thanks!
Crezyoz.
1 解答
2,843 次查看
ProcessorExpert
Senior Contributor III
You can redirect the printf to serial port by redefining the following functions to use serial port:
int __read_console(__file_handle handle, unsigned char* buffer, size_t * count);
int __write_console(__file_handle handle, unsigned char* buffer, size_t* count);
You can find examples in the CW directory - MCU\CodeWarrior_Examples\Processor_Expert\Kinetis\TWR-K70FN1M
best regards
Petr Hradsky
Processor Expert Support Team
在原帖中查看解决方案
3 回复数
2,844 次查看
ProcessorExpert
best regards
Petr Hradsky
2,843 次查看
crezyoz
Thank you for your response. I am not sure how to integrate that with the PE code I have for the K70. The only serial example I found was in the K40 folders.I am new to the K70 and even newer to PE so it's all somewhat of a mystery to me still.
I have successfuly been able to send output to the host using the USB serial connection form the K70 (UART2). But I can not receive any input from incoming characters sent from my terminal. Apparently there is a problem when attempting to use this ? SO I installed the TWR-SER board but it uses the same UART  as the USB serial setup on the K70-TWR.
So I am confused as to what to do next..
I have 3 products to get up and running soon. Is there another way to get faster help with things like this?
2,843 次查看
ProcessorExpert
Look for example at the CRC demo project, the file is {CW MCU v10.2}\MCU\CodeWarrior_Examples\Processor_Expert\Kinetis\TWR-K70FN1M\CRC\Sources\ConsoleIO.c
best regards
Petr Hradsky
