LPC 546XX Chip ID
已解决
LPC 546XX Chip ID
跳至解决方案
3,264 次查看
kellykan
I'm wondering to any of the LPC546XX range of devices have a unique identifier number. For other parts Ive seen where companies record the test X,Y wafer, lot, date and time in otp of non user flash space for trace that can be used as unique identifier. Does any of the LPC parts have such an identifier#?
Kelly
1 解答
3,243 次查看
RaRo
Hello @kellykan,
Could you please take a look at LPC546xx User manual (UM10912). Chapter 5: LPC546xx ISP and IAP. Section 5.6. In-Application Programming and Chapter 7: LPC546xx System configuration. Section 7.5. Register description?
In Section 7.5. Register description it mentions a DEVICE_ID0 (Part ID) and in Section 5.6. In-Application Programming, it is mentioned the IAP Commands to Read part ID and unique ID number.
Best regards, Raul.
在原帖中查看解决方案
2 回复数
3,231 次查看
kellykan
Thanks Raul, exactly what I was looking for
3,244 次查看
RaRo
Hello @kellykan,
Best regards, Raul.
