How to use TDA8029 with a PIC microcontroller?
2,168件の閲覧回数
yosduarangel141
Hello! I'm doing a project with the TDA 8029 and a PIC microcontroller, I'm new at this and I don't know how to establish communication between both by means of I2C and send the commands that appear in the application notes.
タグ(2)
3 返答(返信)
2,017件の閲覧回数
Kan_Li
Please kindly refer to https://www.nxp.com/docs/en/application-note/AN10207.pdf  for details.
Hope that helps,
Kan
2,017件の閲覧回数
yosduarangel141
Thank you very much, the information has helped me a lot. I saw that I can do the communication through I2C, now the doubt I have is how to send the commands to the PIC microcontroller using the ALPAR protocol. I am using the CCS compiler. Although some examples appear in the application note, I'm not clear how to establish communication.
2,017件の閲覧回数
Kan_Li
There is product support package for this device, please kindly refer to https://www.nxp.com/docs/en/application-note/AN11079.pdf  for details.
Hope that helps,
Kan
