How to disable a component once activated.
efbryan
Using the CW/PE downloaded last week.  Clicked on the ADC twice in the CPU and it added it in twice.  How do you delete one of these now that the system has it installed?  I looked for over an hour and could find no documents on how to undo this!
Eric
CrasyCat
Specialist III
Hello
In the ProjectPanel view, expand the ProcessorExpert.pe tree.
Then expand the Embedded Components tree.
You should see your 2 ADC components there. Right click on the one you want to remove and select Remove Component From Project in the drop down menu.
CrasyCat
CrasyCat
Specialist III
Hello
CrasyCat
