GINT RESET making system hang
Amar1
Hi there,
While writing driver for GINT, as mentioned in UM, we need to reset GINT peripheral. When I do GINT reset, the system is getting hanged. The processor is LPC54608.
Please suggest solution to this.
Thanks.
Amar1
Hi Jun Zhang,
Thanks for your reply.
Actually, I found the issue was due to continuous interrupt trigger. It was happening due to polarity mismatch.
Sorry for the inconvenience caused.
Amar
ZhangJennie
You are welcome! Thanks for the sharing.
Have a nice day
Jun Zhang
ZhangJennie
I tested MCUXpresso SDK gint demo below gint reset doesn't cause system hang
RESET_PeripheralReset(s_gintResets[instance]);
Could you please test it as well? Can you use this demo code reproduce your issue?
Jun Zhang
