FreeRTOS_1.199_18.08.2012.PEupd
FreeRTOS
DescriptionFreeRTOS (www.freertos.org) implementation as component. Support for all S08 and all S12(X), ColdFire V1 (CN, JM, QE, JE, and MM families), ColdFire V2 (5225x) and all Kinetis (tested with K40, K60, K70/M4F, KL20Z Freedom Board).
ComponentFreeRTOS.PEupd
DependenciesUtility, FreeRTOSTrace, PercepioTrace
A tutorial how to use the FreeRTOS Embedded Processor Expert component is used can be found here: Tutorial: FreeRTOS on DEMOJM
Attention Classic (non-eclipse) Users!
The component has been tested with CodeWarrior for S12(X) V5.1, which is not eclipse based. The eclipse based CodeWarrior (MCU10.x) is using the concept of an RTOS adapter. The FreeRTOS component has now a setting to disable this. You need to set the setting 'Classic CodeWarrior' to 'yes' in order to have it working in a non-eclipse CodeWarrior environment. Otherwise you will see internal errors during code generation.
Additionally at least the PE 3.09 Service pack needs to be installed. The update is available on http://www.freescale.com/webapp/sps/site/overview.jsp?code=CW_UPDATES_MCU_63, direct link:CodeWarrior for MCU V6.3 Processor Expert V3.09 Update
RTOS adapter settings for classic CodeWarrior
License
License : Open Source (LGPL)
FreeRTOS (c) Copyright 2003-2012 Richard Barry, http: www.FreeRTOS.org
FreeRTOS Processor Expert Component: (c) Copyright Erich Styger, 2012
Processor Expert and CodeWarrior (c) Copyright Freescale Semiconductor, 2012, all rights reserved
This is a free software and is opened for education, research and commercial developments under license policy of following terms:
* This is a free software and there is NO WARRANTY.
* No restriction on use. You can use, modify and redistribute it for personal, non-profit or commercial product UNDER YOUR RESPONSIBILITY.
* Redistributions of source code must retain the above copyright notice.
%3CLINGO-SUB%20id%3D%22lingo-sub-1099481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFreeRTOS_1.199_18.08.2012.PEupd%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH1%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%22%20id%3D%22toc-hId-360439725%22%20id%3D%22toc-hId-1298472569%22%3EFreeRTOS%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20height%3D%22114%22%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%20width%3A%20707px%3B%20height%3A%20104px%3B%22%20width%3D%22705%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%2272%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20font-style%3A%20italic%3B%22%3EDescription%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20width%3D%22770%22%3EFreeRTOS%20(%3CA%20href%3D%22http%3A%2F%2Fwww.steinerberg.com%2FEmbeddedComponents%2FFreeRTOS%2Fwww.freertos.org%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ewww.freertos.org%3C%2FA%3E)%20implementation%20as%20component.%20Support%20for%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3Eall%20S08%20%3C%2FSPAN%3Eand%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3Eall%20S12(X)%3C%2FSPAN%3E%2C%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3EColdFire%20V1%20%3C%2FSPAN%3E(CN%2C%20JM%2C%20QE%2C%20JE%2C%20and%20MM%20families)%2C%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3EColdFire%20V2%3C%2FSPAN%3E%20(5225x)%20and%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3Eall%20Kinetis%3C%2FSPAN%3E%20(tested%20with%20K40%2C%20K60%2C%20K70%2FM4F%2C%20%3CA%20href%3D%22http%3A%2F%2Fde.farnell.com%2Ffreescale-semiconductor%2Ffreedom-kl25z%2Fbord-kinetis-l-serie-kl25z%2Fdp%2F2115294%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EKL20Z%20Freedom%20Board%3C%2FA%3E).%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20font-style%3A%20italic%3B%22%3EComponent%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CA%20href%3D%22http%3A%2F%2Fwww.steinerberg.com%2FEmbeddedComponents%2FFreeRTOS%2FFreeRTOS_1.199_18.08.2012.PEupd%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFreeRTOS.PEupd%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20font-style%3A%20italic%3B%22%3EDependencies%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CA%20href%3D%22http%3A%2F%2Fwww.steinerberg.com%2FEmbeddedComponents%2FUtility%2Fhome.htm%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EUtility%3C%2FA%3E%2C%20%3CA%20href%3D%22http%3A%2F%2Fwww.steinerberg.com%2FEmbeddedComponents%2FFreeRTOSTrace%2Fhome.htm%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFreeRTOSTrace%3C%2FA%3E%2C%20%3CA%20href%3D%22http%3A%2F%2Fwww.steinerberg.com%2FEmbeddedComponents%2FPercepioTrace%2Fhome.htm%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EPercepioTrace%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%22%3EA%20tutorial%20how%20to%20use%20the%20FreeRTOS%20Embedded%20Processor%20Expert%20component%20is%20used%20can%20be%20found%20here%3A%20%3CA%20href%3D%22http%3A%2F%2Fmcuoneclipse.wordpress.com%2F2012%2F06%2F28%2Ftutorial-freertos-on-demojm%2F%22%20target%3D%22_blank%22%20title%3D%22If%20you%20are%20new%20to%20Processor%20Expert%20in%20MCU10%2C%20and%20new%20to%20FreeRTOS%2C%20then%20you%20need%20to%20learn%20two%20new%20things%20in%20parallel%20the%20same%20time.%20That%20might%20be%20overwhelming.%20But%20don%E2%80%99t%20worry%3A%20if%20you%20do%20things%20step%20by%20step%20%E2%80%A6%20Continue%20reading%20%E2%86%92%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETutorial%3A%20FreeRTOS%20on%20DEMOJM%3C%2FA%3E%3C%2FP%3E%3CH2%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%22%20id%3D%22toc-hId-1051001199%22%20id%3D%22toc-hId-1989034043%22%3E%3C%2FH2%3E%3CH2%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%22%20id%3D%22toc-hId--756453264%22%20id%3D%22toc-hId-181579580%22%3EAttention%20Classic%20(non-eclipse)%20Users!%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%22%3EThe%20component%20has%20been%20tested%20with%20%3CSPAN%20style%3D%22font-style%3A%20italic%3B%20font-weight%3A%20bold%3B%22%3ECodeWarrior%20for%20S12(X)%20V5.1%3C%2FSPAN%3E%2C%20which%20is%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3Enot%3C%2FSPAN%3E%20eclipse%20based.%20The%20eclipse%20based%20CodeWarrior%20(MCU10.x)%20is%20using%20the%20concept%20of%20an%20RTOS%20adapter.%20The%20FreeRTOS%20component%20has%20now%20a%20setting%20to%20disable%20this.%20You%20need%20to%20set%20the%20setting%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E'Classic%20CodeWarrior'%3C%2FSPAN%3E%20to%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E'yes'%3C%2FSPAN%3E%20in%20order%20to%20have%20it%20working%20in%20a%20non-eclipse%20CodeWarrior%20environment.%20Otherwise%20you%20will%20see%20internal%20errors%20during%20code%20generation.%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%22%3EAdditionally%20at%20least%20the%20PE%203.09%20Service%20pack%20needs%20to%20be%20installed.%20The%20update%20is%20available%20on%20%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Foverview.jsp%3Fcode%3DCW_UPDATES_MCU_63%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Foverview.jsp%3Fcode%3DCW_UPDATES_MCU_63%3C%2FA%3E%2C%20direct%20link%3A%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DCW08_V6_3_PE_V3_09_SP%26amp%3BnodeId%3D015210272600618680%26amp%3Blocation%3Doverview%26amp%3BWT_TYPE%3DUpdates%2520and%2520Patches%26amp%3BWT_VENDOR%3DFREESCALE%26amp%3BWT_FILE_FORMAT%3Dexe%26amp%3BWT_ASSET%3DDownloads%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ECodeWarrior%20for%20MCU%20V6.3%20Processor%20Expert%20V3.09%20Update%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%22%3E%3CIMG%20alt%3D%22RTOS%20adapter%20settings%20for%20classic%20CodeWarrior%22%20class%3D%22jiveImage%22%20height%3D%22332%22%20src%3D%22http%3A%2F%2Fwww.steinerberg.com%2FEmbeddedComponents%2FFreeRTOS%2Fclassic_no_rtos_adapter.png%22%20width%3D%22450%22%20%2F%3E%3C%2FP%3E%3CH2%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%22%20id%3D%22toc-hId-1731059569%22%20id%3D%22toc-hId--1625874883%22%3E%3C%2FH2%3E%3CH2%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%22%20id%3D%22toc-hId--76394894%22%20id%3D%22toc-hId-861637950%22%3ELicense%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%22%3ELicense%20%3A%20Open%20Source%20(LGPL)%3CBR%20%2F%3EFreeRTOS%20(c)%20Copyright%202003-2012%20Richard%20Barry%2C%20http%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fwww.FreeRTOS.org%22%20target%3D%22test_blank%22%3Ewww.FreeRTOS.org%3C%2FA%3E%3CBR%20%2F%3EFreeRTOS%20Processor%20Expert%20Component%3A%20(c)%20Copyright%20Erich%20Styger%2C%202012%3CBR%20%2F%3EProcessor%20Expert%20and%20CodeWarrior%20(c)%20Copyright%20Freescale%20Semiconductor%2C%202012%2C%20all%20rights%20reserved%3CBR%20%2F%3EThis%20is%20a%20free%20software%20and%20is%20opened%20for%20education%2C%20research%20and%20commercial%20developments%20under%20license%20policy%20of%20following%20terms%3A%3CBR%20%2F%3E*%20This%20is%20a%20free%20software%20and%20there%20is%20NO%20WARRANTY.%3CBR%20%2F%3E*%20No%20restriction%20on%20use.%20You%20can%20use%2C%20modify%20and%20redistribute%20it%20for%20personal%2C%20non-profit%20or%20commercial%20product%20UNDER%20YOUR%20RESPONSIBILITY.%3CBR%20%2F%3E*%20Redistributions%20of%20source%20code%20must%20retain%20the%20above%20copyright%20notice.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1099481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CH1%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%22%20id%3D%22toc-hId-851134846%22%3EFreeRTOS%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CTABLE%20border%3D%221%22%20height%3D%22114%22%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%20width%3A%20707px%3B%20height%3A%20104px%3B%22%20width%3D%22705%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%2272%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20font-style%3A%20italic%3B%22%3EDescription%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%20width%3D%22770%22%3EFreeRTOS%20(%3CA%20href%3D%22http%3A%2F%2Fwww.steinerberg.com%2FEmbeddedComponents%2FFreeRTOS%2Fwww.freertos.org%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ewww.freertos.org%3C%2FA%3E)%20implementation%20as%20component.%20Support%20for%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3Eall%20S08%20%3C%2FSPAN%3Eand%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3Eall%20S12(X)%3C%2FSPAN%3E%2C%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3EColdFire%20V1%20%3C%2FSPAN%3E(CN%2C%20JM%2C%20QE%2C%20JE%2C%20and%20MM%20families)%2C%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3EColdFire%20V2%3C%2FSPAN%3E%20(5225x)%20and%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3Eall%20Kinetis%3C%2FSPAN%3E%20(tested%20with%20K40%2C%20K60%2C%20K70%2FM4F%2C%20%3CA%20href%3D%22http%3A%2F%2Fde.farnell.com%2Ffreescale-semiconductor%2Ffreedom-kl25z%2Fbord-kinetis-l-serie-kl25z%2Fdp%2F2115294%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EKL20Z%20Freedom%20Board%3C%2FA%3E).%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20font-style%3A%20italic%3B%22%3EComponent%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CA%20href%3D%22http%3A%2F%2Fwww.steinerberg.com%2FEmbeddedComponents%2FFreeRTOS%2FFreeRTOS_1.199_18.08.2012.PEupd%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFreeRTOS.PEupd%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%20font-style%3A%20italic%3B%22%3EDependencies%3C%2FSPAN%3E%3C%2FTD%3E%3CTD%3E%3CA%20href%3D%22http%3A%2F%2Fwww.steinerberg.com%2FEmbeddedComponents%2FUtility%2Fhome.htm%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EUtility%3C%2FA%3E%2C%20%3CA%20href%3D%22http%3A%2F%2Fwww.steinerberg.com%2FEmbeddedComponents%2FFreeRTOSTrace%2Fhome.htm%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EFreeRTOSTrace%3C%2FA%3E%2C%20%3CA%20href%3D%22http%3A%2F%2Fwww.steinerberg.com%2FEmbeddedComponents%2FPercepioTrace%2Fhome.htm%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EPercepioTrace%3C%2FA%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%22%3EA%20tutorial%20how%20to%20use%20the%20FreeRTOS%20Embedded%20Processor%20Expert%20component%20is%20used%20can%20be%20found%20here%3A%20%3CA%20href%3D%22http%3A%2F%2Fmcuoneclipse.wordpress.com%2F2012%2F06%2F28%2Ftutorial-freertos-on-demojm%2F%22%20target%3D%22_blank%22%20title%3D%22If%20you%20are%20new%20to%20Processor%20Expert%20in%20MCU10%2C%20and%20new%20to%20FreeRTOS%2C%20then%20you%20need%20to%20learn%20two%20new%20things%20in%20parallel%20the%20same%20time.%20That%20might%20be%20overwhelming.%20But%20don%E2%80%99t%20worry%3A%20if%20you%20do%20things%20step%20by%20step%20%E2%80%A6%20Continue%20reading%20%E2%86%92%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETutorial%3A%20FreeRTOS%20on%20DEMOJM%3C%2FA%3E%3C%2FP%3E%3CH2%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%22%20id%3D%22toc-hId-1541696320%22%3E%3C%2FH2%3E%3CH2%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%22%20id%3D%22toc-hId--265758143%22%3EAttention%20Classic%20(non-eclipse)%20Users!%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%22%3EThe%20component%20has%20been%20tested%20with%20%3CSPAN%20style%3D%22font-style%3A%20italic%3B%20font-weight%3A%20bold%3B%22%3ECodeWarrior%20for%20S12(X)%20V5.1%3C%2FSPAN%3E%2C%20which%20is%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3Enot%3C%2FSPAN%3E%20eclipse%20based.%20The%20eclipse%20based%20CodeWarrior%20(MCU10.x)%20is%20using%20the%20concept%20of%20an%20RTOS%20adapter.%20The%20FreeRTOS%20component%20has%20now%20a%20setting%20to%20disable%20this.%20You%20need%20to%20set%20the%20setting%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E'Classic%20CodeWarrior'%3C%2FSPAN%3E%20to%20%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E'yes'%3C%2FSPAN%3E%20in%20order%20to%20have%20it%20working%20in%20a%20non-eclipse%20CodeWarrior%20environment.%20Otherwise%20you%20will%20see%20internal%20errors%20during%20code%20generation.%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%22%3EAdditionally%20at%20least%20the%20PE%203.09%20Service%20pack%20needs%20to%20be%20installed.%20The%20update%20is%20available%20on%20%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Foverview.jsp%3Fcode%3DCW_UPDATES_MCU_63%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Foverview.jsp%3Fcode%3DCW_UPDATES_MCU_63%3C%2FA%3E%2C%20direct%20link%3A%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fdownload%2Flicense.jsp%3FcolCode%3DCW08_V6_3_PE_V3_09_SP%26amp%3BnodeId%3D015210272600618680%26amp%3Blocation%3Doverview%26amp%3BWT_TYPE%3DUpdates%2520and%2520Patches%26amp%3BWT_VENDOR%3DFREESCALE%26amp%3BWT_FILE_FORMAT%3Dexe%26amp%3BWT_ASSET%3DDownloads%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ECodeWarrior%20for%20MCU%20V6.3%20Processor%20Expert%20V3.09%20Update%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%22%3E%3CIMG%20alt%3D%22RTOS%20adapter%20settings%20for%20classic%20CodeWarrior%22%20class%3D%22jiveImage%22%20height%3D%22332%22%20src%3D%22http%3A%2F%2Fwww.steinerberg.com%2FEmbeddedComponents%2FFreeRTOS%2Fclassic_no_rtos_adapter.png%22%20width%3D%22450%22%20%2F%3E%3C%2FP%3E%3CH2%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%22%20id%3D%22toc-hId--2073212606%22%3E%3C%2FH2%3E%3CH2%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%22%20id%3D%22toc-hId-414300227%22%3ELicense%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23000000%3B%20font-family%3A%20'Times%20New%20Roman'%3B%20font-size%3A%20medium%3B%22%3ELicense%20%3A%20Open%20Source%20(LGPL)%3CBR%20%2F%3EFreeRTOS%20(c)%20Copyright%202003-2012%20Richard%20Barry%2C%20http%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fwww.FreeRTOS.org%22%20target%3D%22test_blank%22%3Ewww.FreeRTOS.org%3C%2FA%3E%3CBR%20%2F%3EFreeRTOS%20Processor%20Expert%20Component%3A%20(c)%20Copyright%20Erich%20Styger%2C%202012%3CBR%20%2F%3EProcessor%20Expert%20and%20CodeWarrior%20(c)%20Copyright%20Freescale%20Semiconductor%2C%202012%2C%20all%20rights%20reserved%3CBR%20%2F%3EThis%20is%20a%20free%20software%20and%20is%20opened%20for%20education%2C%20research%20and%20commercial%20developments%20under%20license%20policy%20of%20following%20terms%3A%3CBR%20%2F%3E*%20This%20is%20a%20free%20software%20and%20there%20is%20NO%20WARRANTY.%3CBR%20%2F%3E*%20No%20restriction%20on%20use.%20You%20can%20use%2C%20modify%20and%20redistribute%20it%20for%20personal%2C%20non-profit%20or%20commercial%20product%20UNDER%20YOUR%20RESPONSIBILITY.%3CBR%20%2F%3E*%20Redistributions%20of%20source%20code%20must%20retain%20the%20above%20copyright%20notice.%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1099481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EComponent%20Exchange%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎09-09-2012 11:51 AM
Updated by:
