Find Hysteresis Value
1,922 次查看
Nirjul_Patel
I used IMX8MM-evk Board So, Can You Explain How to Find Hysteresis Value Any Particular Pin With Example
I Want to  MX8MM_IOMUXC_SAI5_RXD0_GPIO3_IO21 Hysteresis Value so, Please Explain What  a Hysteresis Value Of This Pin
标记 (1)
1 回复
1,833 次查看
Rita_Wang
In the Datasheet and RM do not give this value, but i.MX has 0.25v hysteresis in most cases. You can use 0.25V.
