Errors in using Templated Components and importing Component Setting
Since I want to use some settings of the provious project, I find there are two ways which both don't work. I select the "The LCD"  example project which locals in"\\\Freescale\CW MCU v10.3\MCU\CodeWarrior_Examples\Processor_Expert\Kinetis\TWR-K40X256\LCD".
  • First gererate code,  build and run the project with success. Then I save the processor setting as template and add  it in a empty PE project from the "Component Library", Generate Processor Export code with error "Incorrect Tool Chain Select", I check the new project propeties and change the "Current toolchain" as "ARM  toolchain"  in correpondence with the previous project.  Regenerate the code , there still exit 9 errors in the _arm_start.cfile .
    DescriptionResourcePathLocationType
    Undefined : "exit"__arm_start.c/PE_use_template/Project_Settings/Startup_Codeline 287C/C++ Problem
    Link failed.PE_use_templateC/C++ Problem
    mingw32-make: *** [PE_use_template.elf] Error 1PE_use_templateC/C++ Problem
    Undefined : "__aeabi_unwind_cpp_pr1"PE_use_templateline 0, external location: E:\CW_workspace\PE_use_template\RAM\Cpu_c.objC/C++ Problem
    Undefined : "__call_static_initializers"__arm_start.c/PE_use_template/Project_Settings/Startup_Codeline 251C/C++ Problem
    Undefined : "__copy_rom_sections_to_ram"__arm_start.c/PE_use_template/Project_Settings/Startup_Codeline 231C/C++ Problem
    Undefined : "__init_registers"__arm_start.c/PE_use_template/Project_Settings/Startup_Codeline 179C/C++ Problem
    Undefined : "__init_user"__arm_start.c/PE_use_template/Project_Settings/Startup_Codeline 257C/C++ Problem
    Undefined : "memset"__arm_start.c/PE_use_template/Project_Settings/Startup_Code
    line 229
    C/C++ Problem
  • Second, when I use export "Component Setting"  there still exist the same problems. Can anyone give some hints or advice to this problem?:D
评论
I have solved this question. When I create a new PE project, in the "language and build Tools Options", the  "ARM build tools"  default is GCC, when I select "Freescale", and import the the Processor Export component or board setting,  the new project works. So I believe for this PE example projects, the build tool should be "Freescale" which is different from the default setting.
%3CLINGO-SUB%20id%3D%22lingo-sub-1119390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%E6%A8%A1%E6%9D%BF%E7%BB%84%E4%BB%B6%E5%92%8C%E5%AF%BC%E5%85%A5%E7%BB%84%E4%BB%B6%E8%AE%BE%E7%BD%AE%E6%97%B6%E5%87%BA%E9%94%99%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9B%A0%E4%B8%BA%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%E4%B9%8B%E5%89%8D%E9%A1%B9%E7%9B%AE%E7%9A%84%E4%B8%80%E4%BA%9B%E8%AE%BE%E7%BD%AE%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E6%9C%89%E4%B8%A4%E7%A7%8D%E6%96%B9%E6%B3%95%E9%83%BD%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E6%88%91%E9%80%89%E6%8B%A9%E4%BD%8D%E4%BA%8E%E2%80%9C%5C%5C%5CFreescale%5CCW%20MCU%20v10.3%5CMCU%5CCodeWarrior_Examples%5CProcessor_Expert%5CKinetis%5CTWR-K40X256%5CLCD%E2%80%9D%E4%B8%AD%E7%9A%84%E2%80%9CThe%20LCD%E2%80%9D%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E9%A6%96%E5%85%88%E7%94%9F%E6%88%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%9E%84%E5%BB%BA%E5%B9%B6%E8%BF%90%E8%A1%8C%E9%A1%B9%E7%9B%AE%E5%B9%B6%E6%88%90%E5%8A%9F%E3%80%82%E7%84%B6%E5%90%8E%E6%88%91%E5%B0%86%E5%A4%84%E7%90%86%E5%99%A8%E8%AE%BE%E7%BD%AE%E4%BF%9D%E5%AD%98%E4%B8%BA%E6%A8%A1%E6%9D%BF%E5%B9%B6%E5%B0%86%E5%85%B6%E4%BB%8E%E2%80%9C%E7%BB%84%E4%BB%B6%E5%BA%93%E2%80%9D%E6%B7%BB%E5%8A%A0%E5%88%B0%E4%B8%80%E4%B8%AA%E7%A9%BA%E7%9A%84%20PE%20%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E7%94%9F%E6%88%90%E5%B8%A6%E6%9C%89%E9%94%99%E8%AF%AF%E2%80%9C%E5%B7%A5%E5%85%B7%E9%93%BE%E9%80%89%E6%8B%A9%E4%B8%8D%E6%AD%A3%E7%A1%AE%E2%80%9D%E7%9A%84%E5%A4%84%E7%90%86%E5%99%A8%E5%AF%BC%E5%87%BA%E4%BB%A3%E7%A0%81%EF%BC%8C%E6%88%91%E6%A3%80%E6%9F%A5%E6%96%B0%E9%A1%B9%E7%9B%AE%E5%B1%9E%E6%80%A7%E5%B9%B6%E5%B0%86%E2%80%9C%E5%BD%93%E5%89%8D%E5%B7%A5%E5%85%B7%E9%93%BE%E2%80%9D%E6%9B%B4%E6%94%B9%E4%B8%BA%E2%80%9CARM%20%E5%B7%A5%E5%85%B7%E9%93%BE%E2%80%9D%EF%BC%8C%E4%B8%8E%E4%B9%8B%E5%89%8D%E7%9A%84%E9%A1%B9%E7%9B%AE%E7%9B%B8%E5%AF%B9%E5%BA%94%E3%80%82%E9%87%8D%E6%96%B0%E7%94%9F%E6%88%90%E4%BB%A3%E7%A0%81%EF%BC%8C%20%3CEM%3E_arm_start.c%3C%2FEM%3E%E6%96%87%E4%BB%B6%E4%B8%AD%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E9%80%80%E5%87%BA%209%20%E9%94%99%E8%AF%AF%E3%80%82%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%E6%8F%8F%E8%BF%B0%3C%2FTD%3E%3CTD%3EResource%3C%2FTD%3E%3CTD%3E%E9%80%9A%E8%B7%AF%3C%2FTD%3E%3CTD%3E%E4%BD%8D%E7%BD%AE%3C%2FTD%3E%3CTD%3E%E7%B1%BB%E5%9E%8B%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%20%E6%9C%AA%E5%AE%9A%E4%B9%89%EF%BC%9A%E2%80%9C%E9%80%80%E5%87%BA%E2%80%9D%3C%2FTD%3E%3CTD%3E__arm_start.c%3C%2FTD%3E%3CTD%3E%2FPE_use_template%2F%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%2F%E5%90%AF%E5%8A%A8%E4%BB%A3%E7%A0%81%3C%2FTD%3E%3CTD%3E%E7%AC%AC%20287%20%E8%A1%8C%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%E9%97%AE%E9%A2%98%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E9%93%BE%E6%8E%A5%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FTD%3E%3CTD%3EPE_%E4%BD%BF%E7%94%A8_%E6%A8%A1%E6%9D%BF%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%E9%97%AE%E9%A2%98%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Emingw32-make%EF%BC%9A***%20%5BPE_use_template.elf%5D%E9%94%99%E8%AF%AF%201%3C%2FTD%3E%3CTD%3EPE_%E4%BD%BF%E7%94%A8_%E6%A8%A1%E6%9D%BF%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%E9%97%AE%E9%A2%98%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E6%9C%AA%E5%AE%9A%E4%B9%89%EF%BC%9A%E2%80%9C__aeabi_unwind_cpp_pr1%E2%80%9D%3C%2FTD%3E%3CTD%3EPE_%E4%BD%BF%E7%94%A8_%E6%A8%A1%E6%9D%BF%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%E7%AC%AC%200%20%E8%A1%8C%EF%BC%8C%E5%A4%96%E9%83%A8%E4%BD%8D%E7%BD%AE%EF%BC%9AE%3A%5CCW_workspace%5CPE_use_template%5CRAM%5CCpu_c.obj%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%E9%97%AE%E9%A2%98%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E6%9C%AA%E5%AE%9A%E4%B9%89%EF%BC%9A%E2%80%9C__call_static_initializers%E2%80%9D%3C%2FTD%3E%3CTD%3E__arm_start.c%3C%2FTD%3E%3CTD%3E%2FPE_use_template%2F%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%2F%E5%90%AF%E5%8A%A8%E4%BB%A3%E7%A0%81%3C%2FTD%3E%3CTD%3E%E7%AC%AC%20251%20%E8%A1%8C%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%E9%97%AE%E9%A2%98%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E6%9C%AA%E5%AE%9A%E4%B9%89%EF%BC%9A%E2%80%9C__copy_rom_sections_to_ram%E2%80%9D%3C%2FTD%3E%3CTD%3E__arm_start.c%3C%2FTD%3E%3CTD%3E%2FPE_use_template%2F%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%2F%E5%90%AF%E5%8A%A8%E4%BB%A3%E7%A0%81%3C%2FTD%3E%3CTD%3E%E7%AC%AC%20231%20%E8%A1%8C%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%E9%97%AE%E9%A2%98%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E6%9C%AA%E5%AE%9A%E4%B9%89%EF%BC%9A%E2%80%9C__init_registers%E2%80%9D%3C%2FTD%3E%3CTD%3E__arm_start.c%3C%2FTD%3E%3CTD%3E%2FPE_use_template%2F%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%2F%E5%90%AF%E5%8A%A8%E4%BB%A3%E7%A0%81%3C%2FTD%3E%3CTD%3E%E7%AC%AC%20179%20%E8%A1%8C%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%E9%97%AE%E9%A2%98%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E6%9C%AA%E5%AE%9A%E4%B9%89%EF%BC%9A%E2%80%9C__init_user%E2%80%9D%3C%2FTD%3E%3CTD%3E__arm_start.c%3C%2FTD%3E%3CTD%3E%2FPE_use_template%2F%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%2F%E5%90%AF%E5%8A%A8%E4%BB%A3%E7%A0%81%3C%2FTD%3E%3CTD%3E%E7%AC%AC%20257%20%E8%A1%8C%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%E9%97%AE%E9%A2%98%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E6%9C%AA%E5%AE%9A%E4%B9%89%EF%BC%9A%E2%80%9Cmemset%E2%80%9D%3C%2FTD%3E%3CTD%3E__arm_start.c%3C%2FTD%3E%3CTD%3E%2FPE_use_template%2F%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%2F%E5%90%AF%E5%8A%A8%E4%BB%A3%E7%A0%81%3C%2FTD%3E%3CTD%3E%3CP%3E%E7%AC%AC%20229%20%E8%A1%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%3C%2FP%3E%3CP%3EC%2FC%2B%2B%E9%97%AE%E9%A2%98%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%85%B6%E6%AC%A1%EF%BC%8C%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E5%AF%BC%E5%87%BA%E2%80%9C%E7%BB%84%E4%BB%B6%E8%AE%BE%E7%BD%AE%E2%80%9D%E6%97%B6%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%9C%89%E4%BA%BA%E8%83%BD%E9%92%88%E5%AF%B9%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%BB%99%E5%87%BA%E4%B8%80%E4%BA%9B%E6%8F%90%E7%A4%BA%E6%88%96%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%3AD%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1119390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E7%BB%84%E4%BB%B6%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%BB%84%E4%BB%B6%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E4%BD%BF%E7%94%A8%E6%A8%A1%E6%9D%BF%E7%BB%84%E4%BB%B6%E5%92%8C%E5%AF%BC%E5%85%A5%E7%BB%84%E4%BB%B6%E8%AE%BE%E7%BD%AE%E6%97%B6%E5%87%BA%E9%94%99%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E5%BD%93%E6%88%91%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84PE%E9%A1%B9%E7%9B%AE%E6%97%B6%EF%BC%8C%E5%9C%A8%E2%80%9C%E8%AF%AD%E8%A8%80%E5%92%8C%E6%9E%84%E5%BB%BA%E5%B7%A5%E5%85%B7%E9%80%89%E9%A1%B9%E2%80%9D%E4%B8%AD%EF%BC%8C%E2%80%9CARM%E6%9E%84%E5%BB%BA%E5%B7%A5%E5%85%B7%E2%80%9D%E9%BB%98%E8%AE%A4%E6%98%AFGCC%EF%BC%8C%E5%BD%93%E6%88%91%E9%80%89%E6%8B%A9%E2%80%9CFreescale%E2%80%9D%EF%BC%8C%E5%B9%B6%E5%AF%BC%E5%85%A5Processor%20Export%E7%BB%84%E4%BB%B6%E6%88%96%E6%9D%BF%E8%AE%BE%E7%BD%AE%E6%97%B6%EF%BC%8C%E6%96%B0%E9%A1%B9%E7%9B%AE%E5%B0%B1%E5%8F%AF%E4%BB%A5%E5%B7%A5%E4%BD%9C%E4%BA%86%E3%80%82%E5%9B%A0%E6%AD%A4%E6%88%91%E7%9B%B8%E4%BF%A1%E5%AF%B9%E4%BA%8E%E8%BF%99%E4%B8%AA%20PE%20%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%9E%84%E5%BB%BA%E5%B7%A5%E5%85%B7%E5%BA%94%E8%AF%A5%E6%98%AF%E2%80%9CFreescale%E2%80%9D%EF%BC%8C%E8%BF%99%E4%B8%8E%E9%BB%98%E8%AE%A4%E8%AE%BE%E7%BD%AE%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎04-15-2013 07:04 PM
更新人:
