Errors in using Templated Components and importing Component Setting
Since I want to use some settings of the provious project, I find there are two ways which both don't work. I select the "The LCD"  example project which locals in"\\\Freescale\CW MCU v10.3\MCU\CodeWarrior_Examples\Processor_Expert\Kinetis\TWR-K40X256\LCD".
  • First gererate code,  build and run the project with success. Then I save the processor setting as template and add  it in a empty PE project from the "Component Library", Generate Processor Export code with error "Incorrect Tool Chain Select", I check the new project propeties and change the "Current toolchain" as "ARM  toolchain"  in correpondence with the previous project.  Regenerate the code , there still exit 9 errors in the _arm_start.cfile .
    DescriptionResourcePathLocationType
    Undefined : "exit"__arm_start.c/PE_use_template/Project_Settings/Startup_Codeline 287C/C++ Problem
    Link failed.PE_use_templateC/C++ Problem
    mingw32-make: *** [PE_use_template.elf] Error 1PE_use_templateC/C++ Problem
    Undefined : "__aeabi_unwind_cpp_pr1"PE_use_templateline 0, external location: E:\CW_workspace\PE_use_template\RAM\Cpu_c.objC/C++ Problem
    Undefined : "__call_static_initializers"__arm_start.c/PE_use_template/Project_Settings/Startup_Codeline 251C/C++ Problem
    Undefined : "__copy_rom_sections_to_ram"__arm_start.c/PE_use_template/Project_Settings/Startup_Codeline 231C/C++ Problem
    Undefined : "__init_registers"__arm_start.c/PE_use_template/Project_Settings/Startup_Codeline 179C/C++ Problem
    Undefined : "__init_user"__arm_start.c/PE_use_template/Project_Settings/Startup_Codeline 257C/C++ Problem
    Undefined : "memset"__arm_start.c/PE_use_template/Project_Settings/Startup_Code
    line 229
    C/C++ Problem
  • Second, when I use export "Component Setting"  there still exist the same problems. Can anyone give some hints or advice to this problem?:D
コメント
I have solved this question. When I create a new PE project, in the "language and build Tools Options", the  "ARM build tools"  default is GCC, when I select "Freescale", and import the the Processor Export component or board setting,  the new project works. So I believe for this PE example projects, the build tool should be "Freescale" which is different from the default setting.
%3CLINGO-SUB%20id%3D%22lingo-sub-1119390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%A8%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AFprovious%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E7%A7%81%E3%81%AF%E4%B8%A1%E6%96%B9%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%842%E3%81%A4%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%80%8CThe%20LCD%E3%80%8D%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%80%8C%5C%5C%5CFreescale%5CCW%20MCU%20v10.3%5CMCU%5CCodeWarrior_Examples%5CProcessor_Expert%5CKinetis%5CTWR-K40X256%5CLCD%E3%80%8D%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E6%88%90%E5%8A%9F%E8%A3%8F%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E8%A8%AD%E5%AE%9A%E3%82%92%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%E3%81%A8%E3%81%97%E3%81%A6%E4%BF%9D%E5%AD%98%E3%81%97%E3%80%81%E3%80%8C%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%80%8D%E3%81%8B%E3%82%89%E7%A9%BA%E3%81%AEPE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81%E3%80%8CIncorrect%20Tool%20Chain%20Select%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E5%89%8D%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%97%E3%81%A6%E3%80%8C%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%80%8D%E3%82%92%E3%80%8CARM%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%80%8D%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%86%8D%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%20%3CEM%3E_arm_start.c%3C%2FEM%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%81%BE%E3%81%A09%E3%81%A4%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%E5%BD%A2%E5%AE%B9%3C%2FTD%3E%3CTD%3EResource%3C%2FTD%3E%3CTD%3E%E3%83%91%E3%82%B9%3C%2FTD%3E%3CTD%3E%E4%BD%8D%E7%BD%AE%3C%2FTD%3E%3CTD%3E%E7%A8%AE%E9%A1%9E%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%20%3A%20%22exit%22%3C%2FTD%3E%3CTD%3E__arm_start.c%3C%2FTD%3E%3CTD%3E%2FPE_use_template%2FProject_Settings%2FStartup_Code%3C%2FTD%3E%3CTD%3E287%E7%95%AA%E7%B7%9A%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FTD%3E%3CTD%3EPE_use_template%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3Emingw32-make%3A%20***%20%5BPE_use_template.elf%5D%E3%82%A8%E3%83%A9%E3%83%BC%201%3C%2FTD%3E%3CTD%3EPE_use_template%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E6%9C%AA%E5%AE%9A%E7%BE%A9%20%3A%20%22__aeabi_unwind_cpp_pr1%22%3C%2FTD%3E%3CTD%3EPE_use_template%3C%2FTD%3E%3CTD%3E%3C%2FTD%3E%3CTD%3E0%20%E8%A1%8C%E7%9B%AE%E3%80%81%E5%A4%96%E9%83%A8%E3%81%AE%E5%A0%B4%E6%89%80%3A%20E%3A%5CCW_workspace%5CPE_use_template%5CRAM%5CCpu_c.obj%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E6%9C%AA%E5%AE%9A%E7%BE%A9%20%3A%20%22__call_static_initializers%22%3C%2FTD%3E%3CTD%3E__arm_start.c%3C%2FTD%3E%3CTD%3E%2FPE_use_template%2FProject_Settings%2FStartup_Code%3C%2FTD%3E%3CTD%3E251%E7%95%AA%E7%B7%9A%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E6%9C%AA%E5%AE%9A%E7%BE%A9%20%3A%20%22__copy_rom_sections_to_ram%22%3C%2FTD%3E%3CTD%3E__arm_start.c%3C%2FTD%3E%3CTD%3E%2FPE_use_template%2FProject_Settings%2FStartup_Code%3C%2FTD%3E%3CTD%3E231%E7%95%AA%E7%B7%9A%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E6%9C%AA%E5%AE%9A%E7%BE%A9%20%3A%20%22__init_registers%22%3C%2FTD%3E%3CTD%3E__arm_start.c%3C%2FTD%3E%3CTD%3E%2FPE_use_template%2FProject_Settings%2FStartup_Code%3C%2FTD%3E%3CTD%3E179%E7%95%AA%E7%B7%9A%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E6%9C%AA%E5%AE%9A%E7%BE%A9%20%3A%20%22__init_user%22%3C%2FTD%3E%3CTD%3E__arm_start.c%3C%2FTD%3E%3CTD%3E%2FPE_use_template%2FProject_Settings%2FStartup_Code%3C%2FTD%3E%3CTD%3E257%E5%8F%B7%E7%B7%9A%3C%2FTD%3E%3CTD%3EC%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FTD%3E%3C%2FTR%3E%3CTR%3E%3CTD%3E%E6%9C%AA%E5%AE%9A%E7%BE%A9%20%3A%20%22memset%22%3C%2FTD%3E%3CTD%3E__arm_start.c%3C%2FTD%3E%3CTD%3E%2FPE_use_template%2FProject_Settings%2FStartup_Code%3C%2FTD%3E%3CTD%3E%3CP%3E229%E7%95%AA%E7%B7%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FTD%3E%3CTD%3E%3CP%3E%3C%2FP%3E%3CP%3EC%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%80%8C%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E8%A8%AD%E5%AE%9A%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%82%E3%80%81%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%83%92%E3%83%B3%E3%83%88%E3%82%84%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3AD%3C%2FLI%3E%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1119390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E9%96%8B%E7%99%BA%E7%92%B0%E5%A2%83%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E7%B5%84%E8%BE%BC%E3%81%BF%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1119391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%A8%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%A8%E3%83%A9%E3%83%BC%20%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1119391%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E7%96%91%E5%95%8F%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%20PE%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%5B%E8%A8%80%E8%AA%9E%E3%81%A8%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%84%E3%83%BC%E3%83%AB%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%5D%20%E3%81%A7%20%5BARM%20%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%84%E3%83%BC%E3%83%AB%5D%20%E3%81%AE%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AF%20GCC%20%E3%81%A7%E3%80%81%5BFreescale%5D%20%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%20%5BProcessor%20Export%5D%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E8%A8%AD%E5%AE%9A%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E3%81%93%E3%81%AEPE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E3%80%8CFreescale%E3%80%8D%E3%81%A7%E3%81%82%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎04-15-2013 07:04 PM
更新者:
