DMAController_LDD channel arbitration type bug
3,134件の閲覧回数
bowerymarc
If I select "round robin" for Channel Arbtration Type in the DMAController LDD, when generating code I'm getting the following error:
DescriptionResourcePathLocationType
Generator: FAILURE: Unexpected status of script: Drivers\Kinetis\DMAController.drv, please contact Freescale support.ips-hwtestDMA1Processor Expert Problem
Doesn't happen with Group Arbitration Type.
タグ(1)
2,630件の閲覧回数
vfilip
Hello Marc,
please find the hot-fix attached. Hot-fix is intended for CW V10.5 with installed PEX update 1.0.
Sorry for delay.
(Please apply the patch usual way, copy content of the archive over MCU older within your CW installation)
Vojtech Filip
Processor Expert Support Team
5 返答(返信)
2,630件の閲覧回数
vfilip
I have reproduced in fresh Cw V10.5. Anyway to be sure, could you please post here *.pe file from your project and also specify which CodeWarrior version do you use?
We will prepare hot-fix for you.
We are also sorry for inconvenience.
Vojtech Filip
2,630件の閲覧回数
bowerymarc
any news?
2,631件の閲覧回数
vfilip
Hello Marc,
Sorry for delay.
Vojtech Filip
2,630件の閲覧回数
bowerymarc
that did it thanks.
2,630件の閲覧回数
bowerymarc
Hi Vojtech,
I use CW10.5, I just did the updates as well.
PE file zipped and attached.
Thx
M
