BATTERY MANAGEMENT SYSTEM
1,986 次查看
rj2025
i am working on making a bms for fsae electrical vehicle
i require 13 gpio pins in the cell monitoring unit for temperature monitoring  but in MC33774 only 8 GPIOs pins are present so is there a way to increase number of  GPIO pins by using some ic or by using two MC33774 ics together also if i use a centralized thermistor expansion module would it be able to communicate with s32k3 or will there be any problem
thank you
1,949 次查看
ErikaC
Yes, you can use multiple MC33774 ICs in the same BMS chain or you can check our GPIO Expanders: https://www.nxp.com/products/interfaces/ic-spi-i3c-interface-devices/general-purpose-i-o-gpio:MC_418...
