Using MPC8313EVRADDC in a MPC8313VRADDC design - will there be problem?
2,494 次查看
bsalem
Can there be an issue we will encounter if we use MPC8313EVRADDC in a production design that is currently using MPC8313VRADDC (No Encryption Acceleration). Thanks in advance for your help
2,484 次查看
ufedor
There is no technical issue because Security Engine has to be explicitly initialized to start its computational security functions.
2,372 次查看
bsalem
Thank you for the confirmation.
2,485 次查看
ufedor
