T2081 board
T2081 board
monalihaware
i have custom board with T2081. It was getting connected using HARD CODED RCW (ddr_clk=sys_clk=66.67MHz). Now it shows "failed to configure JTAG chain".
JTAG log is as follows: What might be the problem?
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
       ccs_open; ccs_error = 10
       Error message: Connection refused
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
       ccs_open; ccs_error = 0
ccs_get_connection_count
       serverh = 0
       count = 1
       ccs_get_connection_count; ccs_error = 0
ccs_available_connections
       serverh = 0
       count = 0
       ccs_available_connections; ccs_error = 0
       serverh = 0
       count = 0
ccs_config_cc
       serverh = 0
       config_string = powertap:192.168.1.2
       ccs_config_cc; ccs_error = 0
       serverh = 0
       count = 1
ccs_set_timeout
       serverh = 0
       timeout = 15
       ccs_set_timeout; ccs_error = 0
ccs_cc_status
       serverh = 0
       cc = 0
       ccs_cc_status; ccs_error = 0
ccs_cc_version
       serverh = 0
       cc = 0
       version.major = 1
       version.minor = 0
       ccs_cc_version; ccs_error = 0
ccs_set_timeout
       serverh = 0
       timeout = 15
       serverh = 0
       count = 1
ccs_config_server
       serverh = 0
       cc = 0
       server_config = 0
       value = 10000
       ccs_config_server; ccs_error = 0
ccs_config_chain
       serverh = 0
       cc = 0
       device_list: (size = 1)
              device[0]:: core_type=test core(20)
       ccs_config_chain; ccs_error = 0
ccs_jtag_lock
       serverh = 0
       cc = 0
       ccs_jtag_lock; ccs_error = 0
JTAG Diagnostics
Starting Power at Probe test ...
Test result: PASSED
Starting IR Scan test ...
Test result: PASSED
Starting Bypass Scan test ...
Test result: PASSED
Starting Arbitrary TAP State Move test ...
Test result: PASSED
Detected JTAG IDCODEs: OK
Device 0 IDCODE: 0x118E601D
ccs_jtag_unlock
       serverh = 0
       cc = 0
       ccs_jtag_unlock; ccs_error = 0
ccs_config_chain
       serverh = 0
       cc = 0
              device[0]:: core_type=T2080(242)
ccs_config_template
       coreh = [serverh:0;cc_index:0;chain_pos:0]
       config_reg = 2
       config_data = 1
       ccs_config_template; ccs_error = 0
ccs_write_register
       index = 210001
       count = 1
       size = 4
       value: (size = 4)
               120C0017
       ccs_write_register; ccs_error = 0; duration=1 ms
ccs_write_register
       index = 210002
       count = 1
       size = 4
       value: (size = 4)
               15000000
ccs_write_register
       index = 210003
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210004
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210005
       count = 1
       size = 4
       value: (size = 4)
               6B000002
ccs_write_register
       index = 210006
       count = 1
       size = 4
       value: (size = 4)
               00008000
ccs_write_register
       index = 210007
       count = 1
       size = 4
       value: (size = 4)
               F9027000
ccs_write_register
       index = 210008
       count = 1
       size = 4
       value: (size = 4)
               01000000
ccs_write_register
       index = 210009
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210010
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210011
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210012
       count = 1
       size = 4
       value: (size = 4)
               000307FC
ccs_write_register
       index = 210013
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210014
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210015
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210016
       count = 1
       size = 4
       value: (size = 4)
               00000004
ccs_reset_to_debug
       serverh = 0
       cc = 0
       ccs_reset_to_debug; ccs_error = 39
       Error message: T2080: Core not responding
ccs_get_subcore_error
       serverh = 0
       cc = 0
       error = 5
       chain_pos = 0
       ccs_get_subcore_error; ccs_error = 0; duration=1 ms
ccs_kill_server
       serverh = 0
       ccs_kill_server; ccs_error = 0
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
       serverh = 0
       count = 1
       serverh = 0
       count = 0
       serverh = 0
       count = 0
ccs_config_cc
       serverh = 0
       serverh = 0
       count = 1
ccs_set_timeout
       serverh = 0
       timeout = 15
ccs_cc_status
       serverh = 0
       cc = 0
ccs_cc_version
       serverh = 0
       cc = 0
       version.major = 1
       version.minor = 0
ccs_set_timeout
       serverh = 0
       timeout = 15
       serverh = 0
       count = 1
ccs_config_server
       serverh = 0
       cc = 0
       server_config = 0
       value = 10000
ccs_config_chain
       serverh = 0
       cc = 0
ccs_jtag_lock
       serverh = 0
       cc = 0
JTAG Diagnostics
Test result: PASSED
Test result: PASSED
Test result: PASSED
Test result: PASSED
ccs_jtag_unlock
       serverh = 0
       cc = 0
ccs_config_chain
       serverh = 0
       cc = 0
ccs_config_template
       config_reg = 2
       config_data = 1
ccs_write_register
       index = 210001
       count = 1
       size = 4
       value: (size = 4)
               120C0017
       ccs_write_register; ccs_error = 0; duration=0 ms
ccs_write_register
       index = 210002
       count = 1
       size = 4
       value: (size = 4)
               15000000
ccs_write_register
       index = 210003
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210004
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210005
       count = 1
       size = 4
       value: (size = 4)
               6B000002
ccs_write_register
       index = 210006
       count = 1
       size = 4
       value: (size = 4)
               00008000
ccs_write_register
       index = 210007
       count = 1
       size = 4
       value: (size = 4)
               F9027000
ccs_write_register
       index = 210008
       count = 1
       size = 4
       value: (size = 4)
               01000000
ccs_write_register
       index = 210009
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210010
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210011
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210012
       count = 1
       size = 4
       value: (size = 4)
               000307FC
ccs_write_register
       index = 210013
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210014
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210015
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210016
       count = 1
       size = 4
       value: (size = 4)
               00000004
ccs_reset_to_debug
       serverh = 0
       cc = 0
       serverh = 0
       cc = 0
       error = 5
       chain_pos = 0
ccs_kill_server
       serverh = 0
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
ccs_open
       ipaddr = 127.0.0.1
       port = 41475
       timeout = 15
       serverh = 0
       serverh = 0
       count = 1
       serverh = 0
       count = 0
       serverh = 0
       count = 0
ccs_config_cc
       serverh = 0
       serverh = 0
       count = 1
ccs_set_timeout
       serverh = 0
       timeout = 15
ccs_cc_status
       serverh = 0
       cc = 0
ccs_cc_version
       serverh = 0
       cc = 0
       version.major = 1
       version.minor = 0
ccs_set_timeout
       serverh = 0
       timeout = 15
       serverh = 0
       count = 1
ccs_config_server
       serverh = 0
       cc = 0
       server_config = 0
       value = 10000
ccs_config_chain
       serverh = 0
       cc = 0
ccs_jtag_lock
       serverh = 0
       cc = 0
JTAG Diagnostics
Test result: PASSED
Test result: PASSED
Test result: PASSED
Test result: PASSED
ccs_jtag_unlock
       serverh = 0
       cc = 0
ccs_config_chain
       serverh = 0
       cc = 0
ccs_config_template
       config_reg = 2
       config_data = 1
ccs_write_register
       index = 210001
       count = 1
       size = 4
       value: (size = 4)
               120C0017
ccs_write_register
       index = 210002
       count = 1
       size = 4
       value: (size = 4)
               15000000
ccs_write_register
       index = 210003
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210004
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210005
       count = 1
       size = 4
       value: (size = 4)
               6B000002
ccs_write_register
       index = 210006
       count = 1
       size = 4
       value: (size = 4)
               00008000
ccs_write_register
       index = 210007
       count = 1
       size = 4
       value: (size = 4)
               F9027000
ccs_write_register
       index = 210008
       count = 1
       size = 4
       value: (size = 4)
               01000000
ccs_write_register
       index = 210009
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210010
       count = 1
       size = 4
       value: (size = 4)
               00000000
       ccs_write_register; ccs_error = 0; duration=2 ms
ccs_write_register
       index = 210011
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210012
       count = 1
       size = 4
       value: (size = 4)
               000307FC
ccs_write_register
       index = 210013
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210014
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210015
       count = 1
       size = 4
       value: (size = 4)
               00000000
ccs_write_register
       index = 210016
       count = 1
       size = 4
       value: (size = 4)
               00000004
ccs_reset_to_debug
       serverh = 0
       cc = 0
Tags (2)
alexander_yakov
1. You said: " It was getting connected using HARD CODED RCW (ddr_clk=sys_clk=66.67MHz). Now it shows "failed to configure JTAG chain"." - could you please specify, what is changed?
2. According to your log, the core properly responds to initial commands, but than stops responding. Please verify you target initialization file, what you are doing with the device in this file, and why it stops responding after some step.
Alexander
TIC
