Replacement for MPC8308CVMAGDA
pierce1725
Is there a recommended replacement for MPC8308CVMAGDA? Does NXP have any active parts in the product longevity program that support a parallel local bus similar to the MPC8308?
June_Lu
Both LS1043A and LS1046A  are in the product longevity program until Feb 2035.
They both support parallel local bus IFC which is used to interface with external asynchronous/synchronous devices, such as NAND flash, asynchronous NOR flash, SRAM.
