MPC8309 eLBC UPM mode customization.
1,992件の閲覧回数
avinashpisal
Hi all,
      I am interfacing MPC8309 eLBC bus with FPGA in UPM mode,timing and functional information provided in reference manual is with respective to DRAM interface,
so would like to know,is it possible to configure UPM mode in simple read/write address and control signals format without DRAM compatible interface.
Thank you.
1,644件の閲覧回数
LPP
UPM functionality is not limitted to make DRAM interface only. It is flexible to support various I/O interfaces (SRAM, SSRAM...).
Usefull links:
Application Note "PowerQUICC UPM Configuration" + GUI  tool.
http://cache.freescale.com/files/32bit/doc/app_note/AN2810.pdf
http://www.freescale.com/webapp/sps/download/license.jsp?colCode=AN2810SW.ZIP
Compact Flash Interface Design
http://cache.freescale.com/files/32bit/doc/app_note/AN2647.pdf
Programming the User-Programmable Machine (UPM) for SDRAM  Memory Devices
http://cache.freescale.com/files/32bit/doc/app_note/AN3533.pdf
How to Interface NAND with UPM
http://cache.freescale.com/files/32bit/doc/white_paper/NANDFLASHWP.pdf
1,644件の閲覧回数
avinashpisal
Thank you for quick reply,
i will go through the links you have share here.
