MPC8308 NSG ZFSM 201-2 module
ziedjelassi
I'm trying to test the MPC8308 NSG ZFSM 201-2 module using frescale Beekit. So I need its hardware configure to be loaded.
I have another request, it 's possible to suggest a test technique.
Zied.
manzoor
Dear Zied Jelassi,
                         Were you able to test the zigbee module?
Sheriff
ziedjelassi
Dear Sheriff,
Tell now, this task is in standby. I have got its hardware configuration and some test codes from www.cel.com. Those codes are for the evaluation board version. it doesn't run. it will degenerate in ROM initialization phase. It is the same thing for Beet kit codes.
If you have any idea please help us.
Zied
