How to debug powerquicc using GDB with out USBTAP or CodeWarrior Tap?
wenlantang
Is there any document describe this? Thank.
yipingwang
If you want to bring up your target with GDB, you also need to use CodeWarrior TAP, please refer to "GDB for Board Bringup 1.0 - Getting Started Guide" from  CodeWarrior TAP.
wenlantang
Thank you.
How about below picture in WBNR_FTF10_NET_F0676? What's the interface between host and target board? How do they connected?pastedImage_0.png
yipingwang
You need to use CodeWarrior TAP to connect host PC and the target board.
wenlantang
As I know CodeWarrior TAP is a new product, before that there should be USB TAP between GDB PC and Target board? Should not? So this is a must?
yipingwang
The old product USB TAP doesn't support GDB debug, you need to choose CodeWarrior TAP.
wenlantang
Then what's the connection in the picture of WBNR_FTF10_NET_F0676 pasted above? The doc is on 2010 FTF when the CodeWarrior TAP is not introduced yet.
wenlantang
Could anyone in Freescale answer this?
