How to configure MPC8555E in little endian mode
已解决
跳至解决方案
1,272 次查看
ssa
1. How to How to configure MPC8555E (PowerQUICC III) in little endian mode?
 a. By setting MSR[LE] and MSR [ILE] bit? (8555E RM gives MSR[LE] as OEA defined, but MSR[ILE] is reserved. As per  OEA little endian is configured by both LE and ILE bit)
 b. or on Page basis by setting MASn[E] bit as given in BookE?
2. Any settings has to be changed in Code Warrior (Classic v8.8 for PA) to make programs (structures etc) in little endian.
标记 (2)
1 解答
1,135 次查看
ufedor
1) on Page basis can be used.
2) CodeWarrior operation in little endian mode was not tested.
在原帖中查看解决方案
1 回复
1,136 次查看
ufedor
