How to access 4GB DDR space for p2020?
1,438 次查看
982576385
1,430 次查看
Bulat
The P2020 is equipped with e500v2 cores, the core provides 36-bit addressing, i.e. can address 64GB of memory space. So 4GB of DDR is not a problem.
I would add that the MMU (Memory Management Unit) is responsible for translation of 32-bit accesses to 36-bit address space. Details can be found in the e500 reference manual, see section 12:
https://www.nxp.com/docs/en/reference-manual/E500CORERM.pdf
Bulat
1,427 次查看
982576385
thanks,that is rigth.
but the effective address is 32 bit in p2020,it means that i can only use 4GB memory. where can i place other memory if i used all 4GB for ddr?
can i use on chip memory less than 4GB to access all the 4GB space of ddr simultaneously?
