DPAA 802.3 and Ethernet type 2 packet processing
1,684件の閲覧回数
quiccsmith
Are there DPAA configuration that controls whether to process 802.3 packet versus Ethernet type 2 packets.  Can you provide pointer to the DPAA code which controls this processing? We are suspecting that DPAA is dropping 802.3 packets.  Basically, if the ethertype field = 0x5dc, the packet is dropped. Can you confirm?
Process: P2041
Linux OS
Yoco 2.3: https://source.codeaurora.org/external/qoriq/qoriq-yocto-sdk/linux/tree/drivers/net/ethernet/freescale?h=nxp%2Fsdk-v1.8.x
linux-5.4
https://github.com/torvalds/linux/tree/v5.4/drivers/net/ethernet/freescale
タグ(1)
1,675件の閲覧回数
yipingwang
Please build your Linux Kernel image with the attached Kernel configuration file, then verify whether the packet dropping problem persists.
