Codewarrior TAP shell doesn't have ccs command
Aruna_Jorige
We have recently purchased CodeWarrior TAPs to debug our Power Architecture based boards. CWTAP shell doesn't show "ccs" command. whereas one of our partner uses similar CWTAP, ccs command exists. Is this a firmware issue? Any quick work around for this is appreciated.
Aruna Jorige
yipingwang
I assume that you have installed CodeWarrior for PA 10.5.1, please open ccs console from C:\Freescale\CW_PA_v10.5.1\PA\ccs\bin\ccs.exe, then refer to section "8.2.1 Reprogramming Firmware through Ethernet Port" to update CodeWarrior TAP firmware.
